Question about Philips Magnavox DVD/VCR Dual Player
TV SHUTS OFF BY ITSELF
I TURN THE TV ON AND THE VHS DOOR MAKES THIS CLICKING NOISE THE MACHINE ACTS LIKE IT'S TRYING TO EJECT, THE TV TURNS OFF BY ITSELF AND THE VHS DOOR CLOSES, HELP PLEASE.
  • Edmund Lorenzen
    Edmund Lorenzen Mar 25, 2008
    Have the same problem with a unit I just got... would like some more information on how to find the part to replace so I can replace them. Thanks.
In your experience, does this fix that problem for good, or will it continue to go out. Is this a costly fix? The TV was only $200 something, do these TV have a lot of problems? Thanks!
Posted on Feb 20, 2008
    Sergeant:
  • 395 Answers
There is a infra red emmiting diode inside that has failed. this is the diode just under the prism inside the unit. replace that and re-time the mode switch. the unit is not made by philips but by funai so no support can be given to you from philips. I've repaired close to 60 of these with the same problem you have.
My daughter just had a problem with her Philips tv. It has a built-in vhs player on it, and when she put in a tape, the tv started turning off. I turned it on and got a blue screen that says 't-eject'. I...
It is possible that the Tape mechanism is struck and so is shutting off the power to the unit. Since the power is shared it is possible that the cut off to the set is due to the error in the VHS player.
So in this case you will need to remove the VCR and get the entangled or the stuck up cassette from the player so as to reset the error. Also if there is a mechanical issue to the player must be checked.
Mar 18, 2011 | Televison & Video
My daughter put a vhs in her vcr/dvd combi. Now the vhs is chewed and stuck so it won't come out and the tv and dvd player automatically shut off
Take dvd/vcr combo aparts.Turn on the power to the machine,one hand move around the inter eject vcr port for those sensors,the other hand just keep pushing the eject button,keep doing this until the tape eject and come out.
Jun 14, 2010 | Televison & Video
Trys to eject movie, fails, then shuts off...
the tv must unscrew the cover turn the power felds around for vcr cage for sensor the tape will pop out.push the eject button doing this.
Aug 13, 2009 | Funai F3819D Combo
Tape would not come out.
Not sure on the removal, but if you replace the mode switch the machine might come back to life.
Jul 31, 2009 | Panasonic PV-7400 VHS VCR
VHS got jammed, clicks, turns self off
Open it up and next to the right spindal where the tape goes there should be a small, black B-S button, press it in with a pencil or pin, and it should reset the VCR's computer.
Feb 04, 2009 | Sylvania DV220SL8 DVD Player/VCR
I have a HR-J625EA JVC VCR & video cannot be ejected.
this sounds like a sensor problem the vcr thinks the tape has been ejected and then turns off! this will cost more to fix then a new VCR!
Dec 08, 2008 | JVC HR-S9800 S-VHS VCR
VCR tape won't eject
you should take the bottom off and you will see a gear with a belt around it try to turn it the same direction as when it is turned off, do not force it but it may need a little force to move the wheel.
Mar 17, 2008 | Sony SLV-998HF VHS VCR
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Philips Magnavox DVD/VCR Dual Player Logo
223 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
