Question about Zenith ALGB201 VHS VCR
Recording a tv show
Help!!! my show comes on in 45 minutes. i plugged in the cable from the wall to cable box in...then i plugged a cable from the tv to cable box out. i can watch tv when the vcr is off but when i turn it on i gets blurry. i put it on the show i wanted to watch and i pressed record evnthough it was blurry. when the show was over i watched the tape but there was nothing on it please help!!!
  • laseva Sep 08, 2008
    I want to set it for timer recording but I have no user manual
    Problem Solver:
  • 4 Answers
Make sure the cables going from the cable box to the vcr are not loose as well as the ones from the vcr to the tv.
Posted on Feb 20, 2008
How do i setup my tv through surround sound without a cable box?
Unfortunately Without the cable box you will have to screw the coax cable into the coax input on the tv or You can screw the coax cable into a vcr and then plug the Audio / Video RCA plugs from VCR out to TV RCA input (You will have to control the channels from the VCR and the volume from the TV remote)
Dec 27, 2013 | Samsung Televison & Video
How do i record a show onto a tape?
lets say you are hooked up correctly (cable to VCR in (from cable/sat box) & cable to TV from VCR out) and the VCR is set to Ch 3,, (PLEASE NOTE THE TV MUST BE ON CH 3)
program a recording
the VCR clock / date must be set and not flashing 12:00
then you go to menu, program a recording by imputing the start time / end time of the show and the date it will be recorded and Ch 3...(you might have to set your cable box for the same date/time as the VCR or manually turn to that ch you wish to record that morning or before you go to bed) put a new tape in the machine....
manual recording
a show,game or special comes on and you sitting and want to watch and record and even edit (no commercials) put tape in... press record button get the remote so you can pause (on commercials) and press pause again to resume recording
HAVE FUN
Dec 26, 2010 | Sony SLV-678HF VHS VCR
I turn on the cable box and the tv and about 1 minute to 4 minutes later the tv short circuits and turns off. The cable box is still on. The cable company came to change the box and the cables but it...
Sounds like there is too much voltage going into the same outlet. Please keep in mind cable boxes as well as your tv hold a higher amount of voltage then your dvd player. If your tv is plugged into the back of your cable box, unplug that and just plug it directly into the wall. If not, get a power strip and plug it in that way.
Nov 20, 2010 | Televison & Video
I cant get no picture i have hooked it via hdmi then with the red yellow and white coming from the tv and the cable box i cant do the coaxial because it comes from the wall to the cabe box and the other...
Sounds like the tv is not on the correct input or something. It's hard to say w/ out seeing it. You may need to get someone to check it out for you.
Nov 02, 2010 | Toshiba DR570 DVD Recorder
When i record spanish satalite station the recorded program goes black and white on a regular basis
Well, if the program is showing in color on the TV, then the TV is fine. If she's recording using a VCR, then I presume she doesn't have a cable box? If she doesn't have a cable box and has the cable from the wall going into the VCR and the VCR connected to the TV, then the problem is the VCR if the program appears in color when showing "live" on the TV but black and white when played back on the VCR. Does that make sense? Let me know if you understand what I'm telling you.
Feb 07, 2010 | LG 32LG30 32 in. LCD HDTV
I'm having a truly bizarre issue with my tv! THe
First of all , your TV is good,the DVR from that company are bad. the solution will be to replace with an other brand of DVr and see if the problem still there
Sep 12, 2009 | JVC HD-61FH97 61" Television
My zenith vcr recorder is recording blank but not my tv show and I don't know why. I have it plugged in to my tv - I have cox cable and a tivo box. My cable box runs ino my tivo and then to my tv. My vcr...
It seems to me that you have only got one set of RCA Cablec between the TV and VCR ( from VCR Video out to TV Video In), as such the VCR only works in playback mode, you need a second set of RCA cables (from TV Video Out to VCR Video In) then select the appropriate input (Video) for the VCR. make sure to follow the colour coding on the RCA plug / socket arrangement
Jun 18, 2009 | Zenith VR4206HF VHS VCR
Jeep runs for a minute or two and losses it's spark for 45 min
Sounds like you need to Replace the Ignition Module.
It is a square box located on the side of your fender wall when you lift the hood approx 6 by 8 inch flat box shaped.
Go to auto store and they can show you a pic of it.
It Controls Spark plug Firing.
hope that helped
May 20, 2009 | 1989 Jeep Wrangler
Vcr/dvd combo recording problems
You can use a normal set top box, plugged into the AV inputs on the combo, you could even use a seperate VCR for this, as long as it's recieving the signal you want to record.
Apr 21, 2009 | Toshiba SD-V295
Toshiba Model: SD-V295 DVD/VCR Combo Setup for TV recording
The proper hookup is antenna or cable into the VCR RF/antenna input, then VCR RF/antenna output to the TV RF input. The hookup you describe means no signal is getting to the VCR.
With some TVs, there can be Video and audio output jacks which can be hooked to the video and audio jacks of the VCR. However this would likely mean you could only record the channel being watched, and, the TV would have to be on.
Jun 07, 2008 | Toshiba Televison & Video
Zenith ALGB201 VHS VCR Logo
82 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
