Question about HP Pavillion a818n Desktop PC (Refurb) Pentium 515(2.93Ghz) 512MB 160GB (PS453AAR)
How do I fix the NO Sync on my computer monitor?
  • Jan Lerry P. Aquino
    Jan Lerry P. Aquino May 11, 2010
    Hi, this means that there is no signal from the CPU to your monitor.
    Was there any beep sound when you turn ON your monitor?
    How many beeps and was it a long or short beep?
    Is there a orange or green light on your Monitor?
    Is there a orange or green light on your CPU?
    President:
  • 635 Answers
Check your cable first.
You aren't getting a signal from your video output, so make sure the video card is seated on the motherboard.
If you have onboard video, then you may have other problems
Posted on Mar 09, 2010
Cintiq monitor suddenly won't sync
http://www.conceptart.org/forums/showthread.php/201556-Cintiq-12wx-No-Sync-quot-Message
Oct 10, 2017 | Wacom Cintiq 15X Graphic Tablet
The clock on my computer is always running slow and I have to regularily alter it.
The only way I can think of to 'fix' a pc clock running slow is to set it to automatically sync with an online clock.
You could try a program like NetTime (Link Here) and have it automatically sync it so it's the correct time.
Apr 17, 2013 | Acer AL Computers & Internet
Getting a No sync message on monitor ,computer
No sync message could be for 2 reasons.
1. Loose VGA cable
2. Wrong driver installed or configuration made is out of monitor range
For loose cable you can fix it up from both ends, on CPU and on Monitor itself.
For second reason, we just have to delete display driver from Device Manager. Follow below method to delete driver
Start computer in safe mode. To start in safe mode, as soon the system boots up press F8 and select Safe Mode. After you log into the safe mode. Right click the "My Computer" icon on desktop, go to properties,
go to "Hardware" tab, Click on "Device Manager", go to "Display driver" and expland it, select the driver below the expanded "Display Driver" and press delete to remove the driver. Now restart the system and it will automatically adjust the display driver for you.
May 15, 2010 | Microsoft Windows XP Home Edition
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Picture is rolling
Pinout : Pin Name Direction Color Description
1 RED OUT Red Video (75 ohm, 0.7 V p-p)
2 GREEN OUT Green Video (75 ohm, 0.7 V p-p)
3 BLUE OUT Blue Video (75 ohm, 0.7 V p-p)
4 ID2 IN Monitor ID Bit 2
5 Gnd Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY Key (No pin)
10 SGND Sync Ground
11 ID0 IN Monitor ID Bit 0 GND=Color; NC=MonoMonitor ID Bit 0
12 ID1 or SDA IN Monitor ID Bit 1 NC=Color; GND=Mono Some systems only uses ID0 for monitor ID
13 HSYNC or CSYNC OUT Horizontal Sync (or Composite Sync)
14 VSYNC OUT Vertical Sync
15 ID3 or SCL IN Monitor ID Bit 3
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
HP Pavillion vf15 Monitor flashes off and on rapidly
sounds like the cable is out but i dont know how to fix it srry
Mar 26, 2009 | Computers & Internet
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
and
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Monitor reads: NO SYNC INPUT
YOU HAVE TO CHANGE POWER SUPLY ( buy new )
Oct 15, 2007 | Dell 1200HS D1226H (White) 19 in.CRT...
Computers & Internet Logo
250 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
