Question about ESQ 07300902 Wrist Watch
The watch is not running after replacing the battery, the stop watch part is running.
    President:
  • 2,501 Answers
It could be that the battery has a poor contact. Try cleaning the battery with surgical spirit and avoid handling its faces.(hold the edges).
Clean also the watch contacts.
Posted on Feb 04, 2010
I have replaced battery on my tag heuer 200m professional but it keeps stopping. It will run perfectly for a few minutes or hours then stops. If I unscrew the back case it seems to run ok, bad connection...
did you try installing an other battery ,sometimes batteries are no good.
But your problem can be several things, including battery, or installation of battery not done properly.
Another issue might be that the watch hands have moved and are bumping into each other and stopping the watch from moving. Check the hands and see if they are touching when you turn the crown.
Another issue might be that your movement might be dusty or dirty and will need to be cleaned out. It happens and depending on the age its another likely cause.
Those are the easy fixes and most common causes.
Other issues involving taking the watch apart or fixing / replacing the coil spring.
Jan 23, 2012 | Watches
Elini New Yorker stopped running. could it need a battery? Where can I take it?
Yes, normally if a watch stopped running it needs a new battery. Well, you can bring it to the nearest watch shop in your area.
Sep 17, 2011 | Elini New Yorker Grand Chronograph Red...
Watch runs ok in the light but stops in the dark.The watch is 14 years old
the battery is not holding a charge. replace the battery or sleep with the lights on
Jan 14, 2011 | Citizen Eco-Drive BL006056H Wrist Watch
New battery installed, ran for a few hours and stopped. replaced with another new battery and still not running
Try connecting the case of the battery to the chassis of the watch (use a pair of tweezers).
This seems a common requirement for new battery installation and may apply to your watch.
Mar 19, 2010 | Watches
New watch not working
I would go and get the battery replaced. Watches will run off the battery even when sitting on the shelf in the stores. Replacement are usually less than $10 at the mall or check a jewelry store.
Jan 21, 2010 | Kenneth Cole KC1232 Wrist Watch
Reizen watch stopped running, a year old, seems like a battery problem. How to replace battery?
Take you watch to a jeweler. They will have a stock of batteries. It is better to leave battery changing to those with the correct tools.
Jan 13, 2010 | Watches
Purchased a new pulsar chrono as a gift, the battery was dead, since found out low charge batteries are placed in new watches to check functions but they recommend the battery be change. Problem is,...
I would return it sounds not like a batt. problem but internal mechanical. If you have a reciept dont deal with a potential problem get a replacement.
Dec 26, 2009 | Pulsar Watches
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Dec 14, 2009 | Michele CSX Diamond watch
It stop working, analog and digital
Unfortunately the watch may have been on display for some time and the battery may have run low. If you go back to the place of purchase they should change the battery free of charge. Make sure that you have the watch resealed to manufacturers water resistance rating or you void Sectors warranty. The retailer may also replace the watch with a model in stock but you may have the same issue with display time effecting the battery life.
Sep 17, 2009 | Sector 3251908015 Mountain Master watch
Luminox 3100 series watch stops at night.
It is very possible that the battery is old. They sit in the stores for a while before selling. Good brands of batteries are recommended but not a guarantee of a fresh one. Batteries can be poorly made, lack a proper charge, etc. from the store. I have installed three batteries before on the same watch before finding one that worked. I sometimes have bad luck. I buy batteries in bulk and replace as necessary now.
Dec 03, 2008 | Luminox Watches
ESQ 07300902 Wrist Watch Logo
230 people viewed this question
Top ESQ Watches Experts
Bill Boyd
Are you an ESQ Watch Expert? Answer questions, earn points and help others
