Question about Vizio VF550M 55 in. LCD HDTV
The vizio and the direct tv remote volume is not working correctly, installed new batteries to both. When you push to go up, it goes all the way up and down all the way down. It's like to have a mind of its own. All the other buttons works fine.
I had this problem using dish network. my dish remote went bad so i got a new one and as soon as i programmed it volume and channel had mind of its own on both the dish remote and the original tv remote. you would hit it once and volume would go to max and vice versa when going down. ended up being the new remote was set on the uhf setting and i had to reset to the ir setting which is a small switch in remote next to batteries and then reset system info in dish receiver. problem went away instantly. both remotes work fine now. took two days to figure out and spent hours on internet looking for solution but no one had one. hope this helps.
Posted on Feb 25, 2010
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
Volume does not work on television
Check the batteries.
If you have a digital camera, camcorder or camera phone, turn it on and point the remote at the camera lens. Press the volume buttons on the remote. You should see a flash on the camera lcd screen. If not the buttons on the remote are not working.
Check the buttons on the side/top of the tv to make sure the tv volume is working.
If the remote is dead, sometimes doing the following steps may restore it.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Feb 15, 2011 | Samsung TV Remote Control
My dish remote for my new vizio tv only works part-time. the volume and power work, but the guide button only works less than half the time and only after holding it down for 5 seconds. i have exchanged...
judileighahl,
If you have replaced batteries and had a new remote sent out to you, either the Vizio TV is emitting an IR signal that is interfering with the remote IR signal to the receiver. To test if the TV is emitting interference, is it possible for you to turn the receiver in a direction away from the TV and see if the remote will work? If it does work after moving the receiver, that indicates interference from the TV. If it doesn't change the situation, you might check for other interference from other components (florescent lights, etc.). I hope this helps.
Ray Calo
DISH Network - Executive Offices
Nov 30, 2010 | DISH Network IR Remote Control
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Mar 14, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VF550M 55 in. LCD HDTV Logo
682 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
