Question about Philips Car Audio & Video
Need to identify the cables at the rear of the Philips 22AP120-15 Car booster unit and its rms power per channel(x4)
Slinteriors
  • 8617 Answers
SOURCE: philips 55" hdtv rear projection internal parts
If your model number is 55PP935217 you dont have a ballast. You have a rear projection with 3 CRts . Please let me know if thats the correct model number and what your symptons are. I will be able to help you get what ever part youre needing.
Posted on May 22, 2008
  • 7 Answers
SOURCE: Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Posted on Nov 02, 2008
  • 631 Answers
SOURCE: Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
  • 24 Answers
SOURCE: How much Rms power does the a-6300 put out per channel
The amp is rated at 120wpc on various websites but I suspect that number is too high since the amp weighs only 15lbs. The 400 watt spec is power consumed - not speaker/RMS power.
As for blowing out your speakers, that far more likely to happen with a low powered or cheap amplifier like the GLI A-6300. A low powered amp will quickly burn out a speaker if driven too hard. If you want to protect your speakers from damage, either keep the volume at a reasonable level or buy a bigger amp.
Posted on Dec 28, 2008
SOURCE: philips ajl 750 37 won't connect to comcast cable.
same problem for me
Posted on Jan 07, 2011
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
Mar 23, 2011 | Car Audio & Video
In my boat is a Clarion CMD6 head unit with two rear CMQ1620R speakers, it distorts at medium to high volume, you cant turn it up load when going.Wishing to put two new speakers in the front, cannot cut...
Best bet is to take your boat to a qualified Marine Audio dealer (generally not a boat repair shop or marina), or to a good quality Car audio store that is insured to work on boats (separete insurance usually).
When it comes to boats, you need lots of power and speakers.
First thing to do is make sure what you have is properly installed. Then determine what is "distorting" .. is it too much base, purely volume or what.
Most boats we do (wakeboard style and river boats) we do: 40-75 watts RMS per speaker 4-6 speakers in boat 1 10" or 12" sub with 200-300 watts RMS Tower speaker if requested with 75-125 Watts RMS per speaker
Feb 06, 2011 | Clarion Car Audio & Video
Son puissance max
800 watts per channel @ 4 ohm
400 watts per channel @ 8 ohm
400 watts per channel RMS @ 4 ohm
200 watts per channel RMS @ 8 ohm
Dec 13, 2010 | Gem Sound GemSound PA-2505 Car Audio...
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
    RMS Continuous Power (at 12.0V)
    Per channel into 4 ohms...............40W, 0.08% THD
    Per channel into 2 ohms ..............50W, 0.3% THD
    Bridged into 4 ohms.....................100W, 0.3% THD
    RMS Continuous Power (at 14.4V)
    Per channel into 4 ohms...............60W, 0.08% THD
    Per channel into 2 ohms...............80W, 0.3% THD
    Bridged into 4 ohms.....................160W, 0.3% THD
    Max. Power (at 14.4V)
    Per channel into 4 Ohms..............120W
    Bridged into 4 Ohms....................320W
    This should help.
    Apr 30, 2010 | Alpine MRV-F407 Car Audio Amplifier
    What is the output of the 451s rms power
    Dynamic Power Rating (measured at 14.4V):
    • Bridged Into A 4-Ohm Load: 450 watts x 1
    • Per Channel Into A 2-Ohm Load: 225 watts x 2
    • Per Channel Into A 4-Ohm Load: 115 watts x 2
    Apr 14, 2010 | Rockford Fosgate Punch 401S Car Audio...
    I have a boat with Clarion CM1635 speakers, how do I size the amp for my speakers
    Hello cgregerson,
    If you are running just the front channels to 2 CM1635's, you will need a 2-channel marine certified amp with approximately 50 watts RMS output per channel.
    The MB Quart NAU-260 here would be a good inexpensive choice.
    For a little more power and quality, I'd recommend the JL Audio M2150.
    To run both front and rear channels, you need a 4-channel amp with 50 watts RMS per channel.
    The Kicker MX350.4 marine certified amp would be a good choice.
    Hope this helps.
    Oct 14, 2009 | Cyclone Car Audio & Video
    Hi i was just wondering if anyone could tell me what the max wattage is ?????
    Hiya 50W RMS into 4 ohm per channel (X4) or 70Watt RMS into 2 ohm. The peak rating i think is about 150W
    Jul 11, 2009 | Alpine MRV-F540 Car Audio Amplifier
    Powering 4 6x9 speakers, need amp
    Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
    May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
    Car Audio & Video Logo
    57 people viewed this question
    Top Philips Car Audio & Video Experts
    xxxxxx xxx
    Colin Stickland
    Colin Stickland
    Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
