Question about Toshiba Satellite A135-S2246 Notebook
Have a Toshiba Satellite Laptop A135 which has a cd/dvd rom drive burner that does not seem to be reconized by my system. Under CD/DVD drive in my systems info. it only lists my Magic Jack phone line. When I put in a disk in the drive it makes normal sounds and attempts to run but nothing happens beyond that. I installed the Toshiba Recovery and applications drivers thinking that it may be a software issue, but the disk did install. What could be happening?
    President:
  • 1,738 Answers
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD.
This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This article helps you fix the problem. To have us fix this problem for you, go to the "Fix it for me" section. If you would rather fix this problem yourself, go to the "Let me fix it myself" section.
To fix this problem automatically, click the Fix this problem link. Then, click Run now button from the Automated Troubleshooting Services page and follow the steps in this wizard.
Note This automatic fix only applies to Windows XP and to Windows Vista. If your computer is running Windows 7, go to "Windows 7" under the "Let me fix it myself" section.
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
This problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted Registry entries. To use this method, you must be logged on to Windows as an administrator. If you need help verifying that you are an administrator, visit the following Microsoft Web site: http://support.microsoft.com/gp/admin (http://support.microsoft.com/gp/admin)
To fix it yourself:
Windows Vista;
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.
    Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Posted on Feb 03, 2010
  • 540 Answers
Please follow the steps below to resolve the issue...
Press the Windows Key + R (click on start-->Run) and type devmgmt.msc and press enter.
Device manager will open up.
Click the + sign beside DVD/CD Drives.
Right Click on the device listed under it and select Uninstall
Restart the PC and let the driver install automatically.
Check the issue once again.
Need to replace dvd player in Toshiba Satellite C655
http://www.youtube.com/watch?v=ChrYyWjaEMY Toshiba Satellite C650 L675 DVD Replacement Guide Installation -- L670 C655. Install Fix Replace CD DVD/RW Optical Drive Burner. This guide is useful for these laptop models: TS-L633 - 142, V000210060, C655D, C650D, L675D, L670D
Jan 30, 2013 | Toshiba Satellite A135 Notebook
I have a toshiba A135 Laptop and the cd/dvd drive has stopped working. if I boot from my toshiba system recovery disk via the cd/DVD drive.. How will I know if the drive can be restored to normal...
if you are able to boot from the recovery media then you can justify reimaging the system as it would seem that it is a software issue. backup your files beforehand and you should have no problem.
Oct 26, 2009 | Toshiba Satellite A135 Notebook
Toshiba Satellite A200-1M4 When I start my laptop i can hear a long peep sound and my DVD ROM auto opening. My DVD ROM PC detect but It can not read the CD always showing inset the CD. Please help me in...
dvd burners or rom drive have 2 lens inside, one for DVD read, the other for cd read. I see it often where one fails out in the drive but the other works. With one working fine and the other not, I would replace the drive. If still under warranty send it to manufacturer. If not do a search on Ebay for a replacement drive, or get a local laptop repair shop to do it for you.
May 11, 2009 | Toshiba Satellite A200-16J01D Notebook
Need to remove the cd/dvd drive in Toshiba Satellite A135 S4527 l
Most notebooks have a quick release button underneath for the CD-rom. There may also be a screw holding it in place. It's unlikely that you would have to remove your keyboard to take the dvd drive out.
May 06, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba A135-S24447 cd/dvd burner and drive does not work!
hi good day,
in this situation you need to reformat and reprogram your laptop just to make sure all drivers are working.
Feb 15, 2009 | Toshiba Satellite A215-S5822 Laptop
DVD +R
Right Click My Computer
Click properties
Find and click the hardware Tab
Click The Device Manager Button
This will bring up the device manager in a new window , from here locate your DVD Drive under : DVD/CD ROM Drives
Click the plus sign next to it and the installed CD / DVD Devices will be shown
To uninstall the CD / DVD Rom Right click on it and choose uninstall
To Reinstall Reboot , and Windows Will Automatically Detect The CD-Rom Drive and install it for you
Aug 25, 2008 | Toshiba Satellite A135-S4527 Notebook
My CD-RW/VD-ROM is not reading cd or dvd
on my DVD-rom,
it says 0 free space and 0 used space when i pressed properties
help me???
Aug 17, 2008 | Teac DW 28E CD-RW/DVD-ROM Burner
Problem with cd-r/dvd rom
does the light come on on the drive ? have you tried straightening a paper clip an putting it in to the little hole to push the draw open this may make it work if its stuck or try right clicking the drive in explorer and choosing eject from there
good luck
Jan 23, 2008 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
Toshiba Satellite A135-S2246 Notebook Logo
187 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
