Question about Bosch Dishwashers
New Bosch dishwasher SHE55PO6UC is noisier than expected. I listened to a 50db unit at Sears and the unit I purchased(47db) is not as quiet.The gasket/seal doesn't seem to fit tight against the cabinet opening and there are gaps at the side of the base plate. What type of materials can I use to improve the sound insulation?
  • 1 more comment
  • cdiggins51 Feb 03, 2010
    The question was: What type of materials
    Original posting: New Bosch dishwasher SHE55PO6UC is noisier than expected. I listened to
    SHE55PO6UC is noisier than expected or advertised. I don't think the rubber seal around the unit that contacts the cabinet is sufficient to guard against sound infiltration and the plastic base is ill fitting with gaps at the sides. I think Bosch has cut corners on those two areas and needs to improve or at least offer some type of additional/corrective insulation during installation.
    Sears and the installer are still working on the issue. Bosch says they will only become involved if one of their technicians determines there is a problem with the dishwasher's operation.
    I'm a little discouraged but hopeful for a solution. I will relay this information to the installer and find out if it is useful.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It could be because of the following:
Water-inlet valve an aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan if the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, and then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 03, 2010
  • Rylee Smith
    Rylee Smith Feb 03, 2010
    Sorry I think I misread the question. You can wrap a thermal insulating blanket around all sides specially at the top and bottom. Also there are insulating boards that might help. Also to catch any leaks you can put the machine in a hard plastic or metal box with 4 inches of rubber padding under it. Please check this link for more information. Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
  • 506 Answers
Not trying to play devil's advocate here but how can you prove that your dishwasher is louder than the unit at sears? They are two different test environments. Your house is much more compact with less objects for sound to be absorbed or reflected. Honestly I would not try and modify your brand new dishwasher. This could potentially void your warranty for possible future repairs. If anything check the bracket where it is screwed into the counter top. That possibly could cause a resonance which would make the unit appear to be louder. Take it easy man and good luck with whatever you may decide.
Bosch dishwasher makes noise while draining
If your model has a separate drain pump? You may have something caught in the pumps impellers.
Dec 04, 2013 | Bosch Dishwashers
New Bosch dishwasher makes noise while draining
Impellers on new pumps can do that too , contact your supplier to replace it
Noise Drain Motor? No Cloged
The Bosch units do have a little noisier drain pump than most other units, so if you don't hear a grinding sound it probably isn't something you would worry about, BUT if it is grinding, then it is a sign that either something got sucked into the pump or that the pump is starting to fail.
Jun 09, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch dishwasher noisy vibration
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Jun 06, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHE43MO2UC/48 - Dishes do not dry properly
rinse aid is required to aid the drying process either it is underdosing or the wash programme is too short temps over 55 degrees are needed for satisfactory drying result.
Nov 08, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Bosch dishwasher Start Process
lol...yes this is normal for a Bosch. They have several "safety" measures incorporated into their dishwashers. Look on the bright side they are one of the very best dishwashers on the market and are known for their longevity and quietness.
Jul 31, 2009 | Dishwashers
Bosch SHU 4000 series dishwasher; Water keeps on filling
The inlet valve will be at the dishwasher end of the (hot) water inlet line. On this dishwasher I ~believe~ the inlet valve is near the rear of the unit. That means that you will need to pull the dishwasher out to get to it. Remove power from the dishwasher as soon as you can before messing with the unit.
Just past the connection of the supply hose and the connection on the dishwasher, there will be the valve (a solenoid valve with two wires coming out of it.) That is the little beast that has most likely failed.
Good Luck!
Jan 14, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Got much noisier over time
Hello Hunting2000 the noise could be several things. If you heard what is water hitting against the inner door, try aranging the dishes so that the water is hitting the dishes and not the door. I assume however this isn't the noise you are talking about. Sometimes over time the wash arms themselves will start to make noise. This is from wear. Yes less than a year sounds like a short time. This could have been there from the start. I would call Bosch Customer Support and see if they will pay for a 2nd opion. This well could be the wash arms causing this. Espically the top one not sealing proper and allowing water to hit the front. Hope this helps.
Jan 28, 2008 | Bosch 24 in. SHE44C05UC Stainless Steel...
Bosch Classixx start problem
very possibly your wash motor is jambed. listen carefully when the water is in the unit for a hum. this is the motor trying to start.pull plug from socket then remove R.H.S cover to gain access to motor.at back of motor are cooling fins. if rotor is stuck, try and rotate untill free to turn.
Aug 29, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
74 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
