Question about Mitsubishi WS-65809 65" Rear Projection Television
Mitsubishi 1080 hd
I have a "drooping: blue image at the top of the screen on a 1080 hd mitsubishi. Any ideas?
    Sergeant:
    Champion:
  • 301 Answers
Check and re-solder the connections on the 2 convergence ICs in the middle power board. they are going to be attaches to the biggest heat-sink in the tv. if the re-soldering doesn't fix then replace with STK392-570 i would replace both but if you look at the board you should be able to figure out which chip is responsible for the vertical and which is the horizontal convergence. each IC converges all 3 colors but one is responsible for one axis.
Posted on Feb 20, 2008
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
Mitsubishi WS-65907 rear projection TV HD goes blue.
I would look at the source for the Hd signal as being the problem--if you are using some kind of cable or sat box it will deliver the signal to the DTV input on the back of the set--this is the HD input for this set.
It is possible to have a problem like you describe be one in the set--but very unlikely----have you looked on that green signal board for any signs of Glycol?
Anything that will produce a 1080 signal to the DTV input should tell you if the problem is the set or the source of the HD signal that is causing the problem.
If you have questions or need advice let me know--I am here to help people.
if this information has helped you rate this solution as i do this here for free.
SD TECH
Dec 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi hd 1080
What about the cable input? Does it work?
Sep 05, 2009 | Mitsubishi WS-55805 55" Rear Projection...
I have HD 1080 and the images are sterched at the
You should be able to change the aspect ratios so your images arent distorted.
Jun 15, 2009 | Televison & Video
Blue, green, red parallel curved lines at top of screen
hello sorry but it sounds like the chip have gone again when you replace these chips you might have to change the resistors and the 2 capacitors as well
shaun
May 08, 2009 | Mitsubishi WS-55905 55" Rear Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Yellow and blue ghosting
the DM and of the FMT boards are failing.check out www.tv-techs.com the boards need to be rebuilt
Dec 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
