I just bought this copier and it has error code E0008040000
  • paifloors Feb 03, 2010
    I bought this at auction yesterday and saw it work. It was hooked up to a colater and LAN. I just want to use it as a normal copier so I took off the colater and I wont be hooking it up to anything for now. There is no warranty. The model is a C3220 Cannon imaging center.
    I tried to enter the service mode and it isnt working. Do I need to hold the button for a specified amount of time or hod the additional functions button down at the same time as the #. There is no paper jam or foriegn matierial that I could find on or around the fuser.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If this is a brand new copier then the best thing would be to use the warranty and get it replaced to avoid future issues however, if you want to solve the issue yourself which is not recommended as opening up the unit will void off the warranty, so if you want it to be DIY Job then please revert with the manufacturers name and model no# for your copier.
Thanks
Rylee
Posted on Feb 03, 2010
  • Rylee Smith
    Rylee Smith Feb 03, 2010
    Hi
    Thanks
    for your reply.
    Error E000 means low temp detected in the fuser
    unit, Faulty thermistor, lamp or PCB. Check fuser for jammed
    paper. Its an issue related to the fuser unit. Try and clear the error by
    entering the service mode:
    1. Press ADDITIONAL
      FUNCTIONS, #
    2. Go
      to #7 Printer and press OK
    3. Go
      to #4 Printer Reset and press OK
    4. Yes
    5. Power
      cycle unit.
    If this does not help, on most units you have
    to start looking at your Fixing Assy. or Thermistor. Make sure that you do not
    have a piece of paper wrapped around Upper Fixing Roller or and other foreign
    substance in that area.
    Please do accept the solution if the issue is
    resolved or else revert for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    This is the only way it can be done maybe you can press and hold the button for a longer time frame.
    Thanks
    Rylee
Error code e747 0000
Error code is E747 may be a major cause: There is a fault in the video controller memory
To Fix Error code E747 on a Canon LassetJet LBP-2900 printer, you can try the following: replace the video controller PCB
Try use the printer on another PC you get the same error code return it from where ever you bought it or you will have to get it repaired.
Jul 14, 2014 | Canon LASER SHOT LBP-2900 Printer
Why am i still getting error code 0500 i bought a new fuser unit.
You need to reset the machine, the new fuser does not reset the machine.
May 03, 2014 | Konica Minolta magicolor 1690MF All-In-One...
My Sharp Copier AR 5618 is showing error F2 -64, i have bought a new toner cartridge and installed it yet its still showing F2 -64, please a need a code to clear this problem.
If you don't have a user manual, you can download one in PDF form for your copier at the Sharp website. That may have a legend to explain what the error code means, and how to fix it.
Nov 11, 2013 | Office Equipment & Supplies
C3200 stuck on error screen
did you check the contact from unit 1 and at the back or a connector rest error,power supply board
Feb 18, 2013 | Canon imageRUNNER C3200 Copier
Error code CF70 on toshiba e-studio 600
toshiba e studio600 error codes cf 70
Jul 20, 2012 | Toshiba E-STUDIO 650 Copier
Code E808
This problem was solved by turning off the unit and unplugging the power overnight. The next morning it worked fine.
Jan 15, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Error code E7
check your exposure lamp to fix this
Oct 09, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 27
The error code p27 the toner density sensor unplugged/dirty/faulty
Any problems please get back to me
thank you
Feb 19, 2008 | Office Equipment & Supplies
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
jasbo
jasbo
