Question about Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA CUTTER
Problems with Lincoln LINCOLN ELECTRIC K1756-1 PRO-CUT 25 PLASMA: all settings ok, air ok will spark on occassion and then nothing. tried everything put will only lit very seldom and then nothing.???? probably 15 hours on machine now nothing/ can you buy a control board as this seems to be the problem.
  • 59 Answers
Try using fine sand paper and clean the tip of electrode and the thing that looks like thimble, another solution was don't tighten tip cover too much back off a little til you ge good contact. some units don't like to be clicked ON without making contact with working metal, you may get two or three clicks and then nothing til the air stops flowing.
Posted on Feb 06, 2010
I have a pro cut 25 i would like to change it from 110v to 220v
The pro cut 25 will run on ether 110v or 220v without changing anything. I made a 220v to 110v adapter. It works well and if I want to run it on 110v it will still plug right in.
Dec 05, 2013 | Lincoln Electric Plasma Cutter, Pro - Cut...
Lincoln electric pro cut 80 want arc
Try replacing it as in remove and than put on again
Nov 25, 2012 | Lincoln Electric - Pro-Cut 80 Amp Plasma...
How to change from 115volt to 220 volt on lincoln 25 plasma cutter
There should be a electrical board in the rear under a cover. There are different configureation of some jumpers that can be changed. The diagram should be inside the cover.
Sep 29, 2011 | Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA...
Shuts on on safety ,,almost immediatley
Check that the tip is assembled correctly.If is not in properly, it will not arc. Second, check air pressure switch. Sometimes they become stuck from corrosion due to moisture in the air. Test the operation with a tester
Nov 01, 2010 | Lincoln Electric Plasma Cutter, Pro - Cut...
Start cutting and the safety light comes on
Usually it could be one of two things. The first thing to check for is to look at the contact and make sure it is not melted down and ensure its in good shape. The second thing that could do this, would be not enough air pressure. This air pressure is used to blow away the molten metal you are cutting.
May 29, 2010 | Lincoln Electric Plasma Cutter, Pro - Cut...
When air is hooked up it blows the air regulator and all the air blows out valve very little gets to gun.red safety light comes on on front of machine and it will not work
Air pressure should be no more than 90#s. If regulator cannot handle at least 125#s . Get a new regulater. Sounds like this regulator has a blown diaphram.
Nov 11, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA CUTTER Logo
330 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
