Question about Maytag Neptune MAH5500B Front Load Washer
Error message The door won't open on our Neptune. There is an error message."do"
    President:
  • Maytag Master
  • 2,651 Answers
Remove 4 phillips screws from inside detergent dispensor. you should be able to see a cord eiter neon green or orange, pull firmly on that cord its a manual release.
Posted on Feb 22, 2008
  • 1314 Answers
SOURCE: Maytag Neptune model MAH5500BB
yes you can take off the bottom panel and reach up on the right side toward the door lock there is a plastic like a string there pull it and will unlock door but i need you to email at b4829@yahoo.com with your complete model and serial # may have important info for you
Posted on Dec 30, 2007
  • 65 Answers
SOURCE: neptune washer not starting
open panel at rear of control panel usning phillips head and 5/16 the board attached to that panel will probably have a burnt r14 r1 or r21 resistor. this has been an ongoing problem with this model even a class action lawsuit.(lawsuit expired 9/2005) you can change the board but this will eventually happen again maytag directs you to do a full conversion kit rebuild about $400.
Posted on Feb 18, 2008
  • 34 Answers
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
Posted on Apr 30, 2009
  • 5 Answers
SOURCE: Maytag Neptune door lock stuck!!!
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Posted on Jul 10, 2009
Macmarkus
  • 2605 Answers
SOURCE: Door won't open. Getting an
Hello, Welcome to FixYa.
Hopefully the info below will supply you with the assistance to get the door open for now at least...and a little more... The E4 error indicates a door kock error, however the door typically locks as a result of the unit failing to drain, so....
1. **Unplug the washer from the wall or turn off the breaker before attempting any repairs**
2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)try a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand or with the aid of pliers.
**NOTE - you should also see a ring attached, if you pull this the door should unlatch, but getting the water out first if present is usually a good plan
Once the door is open, unplug the washer for 20minutes or so and then plug it in again, to see if the control "resets". Good luck !
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly. (Sorry about the post, I'm still adapting to this "htc" windows 7 phone after having an iphone for 2years...very tricky lol )
Thank you for choosing to "FixYa".
Regards,
Macmarkus :)
Posted on Jul 23, 2011
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
I own a maytag neptune washing machine. It was working o.k. and suddenly it won't start. I push the start button and it buzzes and shows a message that says,"It appears the door was not opened...
Hi Debi:
First I suggest to try unplugging the unit for 60 seconds to reset the control board. If that doesn't work then open the dispenser and remove the softner and bleach container. There is a cord near the front you can pull to open the door lock. If you still have issues with your door lock after manually opening the door, you will need to order and replace the door latch assembly.
Also I could bet you need to replace your door latch assembly. Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 06, 2011 | Maytag Neptune MAH7500A Front Load Washer
ERROR CODE NP AND NOW DOOR WON'T OPEN
Hello first try unplugging the machine for 7 minutes if this doesn't then allow you to open the door then you can manually release the door lock by taking off the dispenser assebly holder (bezel) and pulling on the door lock release cord you will find inside. Also as far as the nP I think the erro your seeing is ND which is no drain in which you can click this link
http://www.fixya.com/support/t340703-maytag_neptune_error_code_nd another tech has posted with pictures on this issue. IF you have any further questions message me back Thanks
Rick
Sep 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
Hi! getting od error and waher will not let me start any cycle
Hello, the "od"error you getting means the control did not detect that the door was opened between washes. Try opening and then closing the door again and if the error message is still present, there may be a problem in the door switch mechanism, the electronic control or the wiring between the two.
Thanks
Jun 05, 2010 | Maytag Neptune MAH6700A Front Load Washer
Try these steps:
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Thanks
Apr 29, 2009 | Maytag Neptune MAH7500WH Front Load Washer
Excellent, glad to hear we could help.
Jun 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dec 30, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
210 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
