Question about IBM Office Equipment & Supplies
WE have a Selectric 5-- our carriage return is sticking and changes the left margin when we use the stored information, it will reset in the middle of the information.
  • info48371 Feb 03, 2010
    Thank you for your assistance but it did not help much. I called a local service person who suggested I try wiping the carrier rods with 3 in 1 oil which solved the problem.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you might require it to be cleaned from inside, while cleaning if you want to use an oil, just use non detergent electric motor oil. Also the motor can be lubed however the carrier Return works by a cam mechanism, a series of spring loaded latches and a spring clutch-- quite complicated for the uninitiated. So it’ll be good if you get this job done by a professional as you have to open the unit to clean everything up. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 03, 2010
  • Rylee Smith
    Rylee Smith Feb 03, 2010
    Thanks
    Rylee
Selectric II Pitch-shift lever won't change from 12 tom 10
If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
DickyO
May 16, 2012 | IBM Correcting Selectric II
IBM selectric II carriage stuck in right margin
There is a thin metal ribbon in the back that has come off the wheel. It is a devel of a thing to get back on.
Remove the cover and watch ... you will see what I am talking about.
It may have come un-attached ... equally difficult to fix without the little thingie the typewirter mechanic uses.
good luck
Oct 14, 2009 | Office Equipment & Supplies
My IBM selectric II typewriter carriage stuck in right margin
Sounds like the return lever arm is not putting enough pressure on the return clutch, or the clutch is slipping. The exp key uses the same clutch but the pressure comes from your finger. Theres no way you can fix this yourself. Get an IBM mechanic.
Oct 14, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Selectric II keeps returning to right.
Check the pitch lever on the top L. of the cabinet it may be in between positions.
DickyO
Sep 08, 2009 | IBM Office Equipment & Supplies
IBM Selectric II-return goes past the margin stop
The margin release mech. is probably gummy and allowing returns to go past the margin. If thi is a dual pitch machine see if the pitch selector lever will move easily. If not use some WD40 on the margin rack.
DickyO
Mar 11, 2009 | Lexmark Wheelwriter 15 Series II...
Coronomatic 2200 carriage return stops advancing
It sounds like you are coming up against your right margin. By hitting release you are merely bypassing the margin. You might try resetting your right margin by clearing it all the way to the right side of the carriage first then resetting it to where you want it.
Jan 28, 2009 | Office Equipment & Supplies
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
IBM Selectric II
R152
Sounds like you have a broken torquo limiter tension spring you should have it professionly serviced.
DickyO
Jul 07, 2008 | Office Equipment & Supplies
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Return sticks
Try putting a few drops of light oil on the shaft that the carrier rides on and the pulleys that the cables are on (WD40 works well) also look for debris under the carrier.
Merry Christmas
DickyO
Dec 27, 2007 | Nakajima AE-740 Typewriter
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
