Question about Epson MovieMate 72 3LCD Projector with Built-In DVD Player
Epson moviemate72 projector
Hi i have epson moviemate72 projector, when i turn on it seems normal for about five minutes then red lights turn on with high cooling, after about 3 mins it shuts down, then try again same issue, also cant eject dvd, when unit is doing its cooling front display says switch, need help maybe how to clean or could it be thermo switch..note.. unit only 2 years old and been used 8 times. thankyou
  • 115 Answers
SOURCE: projector problem - Epson EMP-S1H Multimedia Projector,
try to reset lamp by using menu, up, down and enter buttons. also reset the filter and try again.
Posted on Nov 27, 2007
  • 1447 Answers
SOURCE: Epson s1
before you send it to a repair shop pls try to remove all the devices that you attach to it and check if you are still going to get those light whites after awhile, or try using a different device in which it uses a different cable, did you attach a receiver as well from the tv to projector? try changing the cables as well. update me after you performed this steps, if it resolve it pls rate as fixya if not pls reply back. Thanks!!
Posted on May 10, 2008
  • 563 Answers
SOURCE: Epson ELP 5500 projectors
Hi technoteach
Will try and get my hands on a Service Manual for this model - in which you would find the circuit diagrams. This is a faulty Mainboard that is causing the problem.
Posted on May 13, 2008
SOURCE: Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Posted on Oct 07, 2008
  • 2237 Answers
SOURCE: My Epson EMP-TW20 projector has consistantly
clean it out with canned air. the dust keeps in the heat that the projector is trying to expell. you may need to replace the temp sensor, as the constant heat may have weakened the sensor.
Posted on Nov 19, 2009
How to fix wonderwall projector after being unplugged while red light and fan were running
PDF]Download - MS Customer Care
getting started with the projector. 14 n. (1 se') ... I The projector can project up to 90" (228 cm) diagonal image. ... I Once powered on, the fan and the lamp will run instantly.... WHILE THE RED LIGHT IS BLINKING ... light bulb. I Turn off the projector, unplugthe power and allow it to cool for 30 minutes as it runs at an.
[PDF]Checking Projector Status - Epson
EpsonIf your projector isn't working correctly, first turn it off and unplug it. Then plug the ...doesn't solve the problem, check the lights on top of the projector. What To Do Whenthe Lights Flash. The lights on ... If you continue to use the lamp after the ... P Red. Off. Flashing red. There is a problem with the fan or temperature sensor.Missing: wonderwall
Canon Knowledge Center - Turning On and Off the Projector
Jan 18, 2016 | Sharper Image Wonderwall Entertainment...
Epson EMP 500 turning off
I believe that's an overheat problem. Check the fan if it's cooling properly. Make sure the unit is in a cool temp room.
Nov 01, 2008 | Office Equipment & Supplies
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Can't get my epson 450wi to turn on shows red
What shows red? If all 3 lights are flashing red you are out of luck. If it is under warranty call Epson. If your warranty has recently expired I would still call Epson. This is a "known issue" for this model projector.
Mar 06, 2014 | Epson BRIGHTLINK 450WI Projector
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
The cooling fan stop working on my Epson EMP 700 Multimedia Projector, can I get a replacement part and replace it myself?
The temperature indicator is red.
automatically. Let the projector cool for a few minutes,
then turn it back on. Make sure nothing is blocking the
ventilation vents.
If the projector continues to overheat after you clean the air
filter, the problem may be caused by damage to the cooling
fan or internal circuits. Contact a qualified service person.
ยจ Warning: Do not attempt to service this product yourself except
as specifically explained in this User's Guide.
Representative : EPSON AMERICA, INC.
Address : 3840 Kilroy Airport Way
MS : 6-43
Long Beach, CA90806-2469
Telephone : (562) 290-5254
Jan 17, 2011 | Epson EMP 700 Multimedia Projector
Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
Feb 21, 2009 | Epson (V13H010L34) Projector Lamp for...
Warning lights
Just so you know guys (and this procedure is not for the faint hearted!). I had the slow one second red warning light flash. I checked the bulb, which was find and I left it powered off for 48 hours. My projector is no longer under warranty and would have cost me over £300 to have it looked at. I ventured inside to inspect the boards, once I removed the main board to check the power supply I heard movement from one of the light ducts. It took me a while to removed enough to discover the fixing screw which holds the imaging cube in place (which is between the 3 light ducts and the projector lens) had come out (!?) and was rolling around inside the unit. This would also explain why sometimes I could not focus my unit properly. I remounted the imaging cube, put the whole thing back together and PRESTO! My projector is working again.
Jun 21, 2008 | Epson EMP 720 Multimedia Projector
Epson EMP-74 - Blinking Red Light
Hi Sootycat
Ok , most of the time this would be the Fan.Powerboard that is faulty then and unfortunatelly it would be better to replace the part rather than having it repaired.
Repaired Powerboards normally give the same problem a couple of months down the line.
Apr 15, 2008 | Epson EMP-54 Multimedia Projector
Epson MovieMate 72 3LCD Projector with Built-In DVD Player Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
