Question about Sanyo VPC-E760 Digital Camera
Small plastic piece (with small spring) that holds battery in battery compartment is broken. I can not find a replacement part. Problem for Sanyo VPC-E760 Digital Camera
  • 2,517 Answers
If you visit Sanyo service center, then they will provide you that parts. Thanks.
Posted on Feb 03, 2010
GE Wireless 2.4 GHz Mouse 99914 can't get batteries in it
Right below the storage compartment for the USB Nano receiver is a small lip clip. You can try to light it up carefully with your nail or a small tool and the whole plastic piece holding the batteries in place will lift up. You then will be able to insert the batteries. Remember this is a plastic piece so it can break easily. Hope this helps.
Apr 01, 2013 | GE Wireless Optical Mouse
Grmini quest2 is not turning on and is not rosponce for charging
this is most likely a bad battery. Replacement batteries are available on Ebay and also Batteryship.com. You will need a small screwdriver (Batteryship sends one with the battery). Place the unit face down on a table. Remove the 6 screws from the back. Be careful when removing the two screws on the right that hold the flip up antenna. There is a small spring and plastic piece that can fly out unexpectedly and I will guarantee they will disappear forever. Remove the back cover and you will see the battery. It will probably be held in place with some adhesive. Gently pry it from the unit. The battery connects to the circuit board with a small white plastic plug. Gently remove the battery from the plug and set it aside. Plug in the new battery and reverse the process of putting the back cover on. Don't forget to put the small spring and plastic piece in properly on the right side of the antenna. Put the unit in a charging cradle and let it charge overnight and you should be set.
Dec 16, 2012 | Garmin Quest GPS Receiver
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Camera door thats holds battery small grey latch is broken
    Try partstore.com they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
    Sep 21, 2009 | HP R967 Digital Camera
    HP 7410xi small plastic piece in print cartridge carrier broken
    If the spring did not damage the carriage flex I would suggest just using some epoxy to hold the spring properly in place. If the spring did damage the flex (as shown in this picture) then you might contact HP and enquire about an extended warranty for this issue. In the US call HP at 1-800-HPINVENt.
    Regards,
    Bob Headrick, MS MVP Printing/Imaging
    Dec 13, 2008 | HP OfficeJet 7410 All-In-One InkJet...
    Battery
    getting that piece is very difficult and can be obtained only from the sanyo service centre... but on the other hand u can try optionally do a fix by urself to hold th ebattery in it...
    Sep 16, 2008 | Sanyo VPC-E760 Digital Camera
    HP Photosmart R927 Battery Compartment door latch
    Same problem, The small plastic tab that extends into the slot to keep the battery compartment door broke off. I can't locate a source for replacement part. I disassembled the slide and reversed it, breaking off the little tip that fit into spring, and it sort of works, but a new plastic slide would be much better.
    Mar 21, 2008 | HP Photosmart R927 Digital Camera
    Replace Staples
    Sounds like something has broken.
    Best to place a service call for this.
    Jan 23, 2008 | Konica Minolta bizhub C450P Laser Printer
    Sanyo VPC-E760 Digital Camera Logo
    94 people viewed this question
    Top Sanyo Cameras Experts
    ray gallant
    Are you a Sanyo Camera Expert? Answer questions, earn points and help others
