Question about Dell 1815dn All-In-One Laser Printer
On 2/1 and then again on 2/3 we have received an error message " Open Heat Error". At that time the printer would not function. Upon shutting down, and turning back on the message was removed...but this is the second time in three days. What do you suggest?
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Any heat errors on the dell 1815 means the fuser has gone bad. Your best bet is to replace the fuser, part # UG297. Here is a video that shows you how to replace it. Iteminc.com has these in stock and ships same day (till 7pm est). Hope this helps, Good luck!
Posted on Jun 06, 2011
  • 525 Answers
Clean thermistor if dirt or Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Posted on Jan 21, 2011
Setup/configuration issue, error message, scanner error 0x10. How do I fix this?
unplug power at the wall outlet
wait 5 minutes
press and hold the power/on button for 60+ seconds
keep holding while plugging back in, and for another 60 seconds after, then release if that doesnt work it is an internal fault which would require repairs or exchange in your case
Jul 19, 2015 | Epson Expression Home XP-420 Wireless...
Canon IR 330s - i have error message E004. how do i clear it?
This is an error for the thermistors in the fuser not reading temp correctly. Go into service mode by the standard Canon way - Additional Function key, 2 & 8 held down at the same time, then Additional Function key. Press copier, function CLEAR, ERR, then OK. Power cycle the copier and the error is reset. Again if the error come back you will have to check the fuser assembly, heat lamps, thermistor, thermofuse, etc. There is a problerm thsat needs to be fixed and continuing to reset may do major damage to the copier.
Jun 22, 2011 | Canon ImageRUNNER 330s Copier
Error Code: 39,003.40:133671 Yesterday the copier/scanner would not work. I shut the printer down and restarted it and received the above error code. I shut the printer down again and restarted it and...
this is a scanner problem that can be associated with the scanner lock under the scanner bed. make sure the lock is in the 'unlocked' position. it is easy to move this when lifting the scanner bed to reload the ink blocks. if this does not solve the problem you may have to replace the scanner assembly. hope this helps.
Aug 19, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
My canon mf3240 printer jamed, then a b5 paper size error message
You must be set you machine from program key
1> press menu>paper size>A4/Letter/set OK
after print or copy your requirement size.
Dec 12, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Ink sys failure error message
Try the following steps and check if it resolves the above error.
1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Print a Self Test to verify product is functional.
9. Reconnect the USB cable, and try to print from the computer.
Wish
Aug 01, 2009 | HP Photosmart D7160 InkJet Printer
Error code 000002-0010
You need to clear this fuser roller heat rod error in svc mode.
Additional Functions="star"
2and8= hit both keys same time.
Svc mode= star 2and8 star
copier/functions/clear/err/ok
reboot
If there is areal problem with fuser heat rods it will code again.
Nov 08, 2008 | Canon imageRUNNER 5000 Copier
Oxc18a0101 error message - C6180 All-In-One
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plugthe power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
Oct 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer Error Message after changing the cartridges
I'm not even pulling up any info on that error msg.
Where are you reading the error msg from, within Windows? Or from the printer itself?
Oct 23, 2007 | HP PSC 2355 All-In-One InkJet Printer
Dell 1815dn All-In-One Laser Printer Logo
394 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
