My LG Plasma 50PX1D popped and now shows a dark blackened image with sound. Could it be the x, y or z sus boards? If so, which one would most likely be the problem and how do I test them? Thanks
  • 4,889 Answers
You mean you heard a pop sound before the display went dead? If yes then you will probably be able to look for tell-tale signs of damage. Look for anything like a blown fuse, a charred area on the board, Cracked leaky or swollen capacitors(usually at the tops), expanded transformer(if the coil is damaged). Check all 3 sustain boards and also the logic control board and post back with your observations.
Sai.
Posted on Feb 11, 2010
Red/green/blue static toward top of screen
Very likely either the YSUS board is going bad and/or the power supply voltages are getting noisy because of failing capacitors.
Dec 02, 2013 | LG 50PX1D 50 in. Plasma Television
The screen on my LG tv is not showing a picture. it has red and green pixels in the centre of the screen and has sound only.
y-sus board bad but make shure you look at buffers for pop marks there will be small ic.s on each buffer board look for small white pop marks on them but most likely its just the y-sus board
Feb 03, 2010 | LG RZ-42PY10 42 in. HDTV Plasma
LG Plasma 42pc3d turns on, pops, then turns off
The first thing you should look into is the Z-SUS board, the one situated on the right side viewed from the rear. This board develops a high voltage during operation that might be the source of the popping sound. It is also responsible in refreshing the panel for proper picture display. The weird colors on your TV indicates a faulty Z-SUS board.
Note: Unplug the TV and wait for at least five minutes in order to allow the voltages to drain before you disconnect or reconnect any connector.
  • Disconnect the Z-SUS board from the Y-SUS board. The Z-SUS board is situated on the right side viewed from the rear of the TV while the Y-SUS is on the left.
  • Plug the TV back and turn it on.
  • You will still be able to see the weird colors the moment the TV shut off but do not flash. If it does not pop and stays on and there's a sound, you are pretty sure the Z-SUS board is faulty. Replace it.
  • If it still pops and shuts off, disconnect the Y-SUS board from the power supply. The Y-SUS board also develops a high voltage during operation. The power supply is the one right between the Z and Y-SUS boards.
  • Re-apply AC power then turn the TV on.
  • You'll not be able to see any color or video. If it does not pop and stays on with sound, you have a faulty Y-SUS board, replace it.
  • If it still pops and shuts off, please let me know.
Feel free to update me of the result and your own findings.
Dec 03, 2009 | LG 42PC3D 42 in. Plasma Television
As I was watching TV last night, my 50" LG Plasma TV 50PX1D, and it made 3 loud "popping" sound, and you can barely see the images. The picture is not jumping & the color doesn't appear to be fading in...
Either X,Y, or Z-boards seem to have developed a problem, when this happens it results in a 'sound-no-picture' condition. If its under warranty take it back, if not have your local tv repair center fix it for you....
Oct 18, 2009 | LG 50PX1D 50 in. Plasma Television
Red screen vague picture sound is excellend
Well it takes a good Y and Z to make a good picture.
Slow turn-on sounds like power supply problem to me, although I've worked more on LCD sets than plasma, so I could be wrong.
Here's an ebay link that tells how to test your Z, and coincidentally has a Z board for sale.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350088827899
Oct 16, 2009 | LG 50PX1D 50 in. Plasma Television
LG 50PX1D (Popping noise)
Hi you need the y-sus board. You May find it @ partstore.com Thanks.
Sep 21, 2009 | LG 50PX1D 50 in. Plasma Television
LG 50PX1D Plasma TV with dark and fuzzy picture
Z-Sustain PCB will cure it.
It is inside the TV, on the Right Hand Side.
www.chsinteractive.co.uk or Google for a replacement.
Sep 08, 2009 | LG 50PX1D 50 in. Plasma Television
Model 50px1d - uc loud pop and now picture lacks brightness and definition what do i need to replace
i would replace both the z-sus and y-sus boards. These should be replaced by a technician as some adjustment is needed afterwards.
Aug 14, 2009 | LG 50PX1D 50 in. Plasma Television
42 inch LG Plasma TV - Lost picture
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Sep 16, 2008 | LG 50PX1D 50 in. Plasma Television
My LG Plasma TV RU42PX10C
Hi all..i had the same problem with my 42 inch LG
rz42px11. its a faulty zsus board(Z sustain part no 6871QZH033A) the pop
sound was the fuse on the board blowing.not that hard to replace but be careful with the connector ribbons! got my replacement from
https://www.chsinteractive.co.uk/ £150....expensive,but probably cheaper than
calling someone out to fix it.
P.S i tried just to replace the fuse on the board T2AH 250v but it blew,i think the fact the fuse blows means the board is faulty..but you could try.
hope this helps someone.
Good Luck
Dec 21, 2007 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
