Question about Dell Precision Workstation 670 PC Desktop
My Dell 670 had a blue screen when the c drive
My Dell Precision 670 had a blue screen when the c drive failed. I replaced the drives and at first the machine would take a long time to turn on, about 3m minutes. Now the power button flashes yellow and there are two yellow lights on the left in front. I think this means some kind of power or installed device problem but I can not isolate it. Machine does not want to power up
  • 32 Answers
Try to remove or detach any newly hardware.and check the Ram
Posted on Feb 04, 2010
Dell precision 670 diagnostic lights y g y
http://www.dell.com/support/Manuals/us/en/19/Product/precision-470
Click on -
Dell Precision Workstation 470 and 670 Computer User's Guide
In the list on the right side, click on - Tools to Help Solve Problems
In the list on the left side, click on - Diagnostic Lights
Yellow (A) Green (B) Yellow (C)
"A possible VRM 1 failure has occurred"
VRM stands for Voltage Regulator Module.
It regulates Voltage for the Processor.
The Processor MUST have a steady, 'clean', supply of Voltage; and it MUST be kept within the tight voltage range, for the Processor.
Too little, or too much; and the Processor turns off. (BIOS turns it off)
Your motherboard supports two Processors.
1) Processor (CPU_0) Zero which is in the middle of the motherboard, next to the PCI Express x16 slot;
2) and Processor (CPU_1) One, which is next to it.
The VRM 1 has failed. Needs to be replaced.
http://www.ebay.com/itm/DELL-H2703-PRECISION-470-670-VRM-VOLTAGE-REGULATOR-MODULE-TH-0H2703-WS470-WS670-/380369885440
VRM's used are interchangeable.
IMHO you can remove Processor 1 (CPU_1), and it's VRM, and still use the computer; albiet slower though.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 22, 2013 | Dell Precision Workstation 670 PC Desktop
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
Dell Precision 670 RAID1 Install on Windows 7
The RAID configuration maybe setup in the BIOS settings.
Mar 31, 2012 | Dell Precision Workstation 670 PC Desktop
I have had problems when starting from cold - the workstation dell Precission 670 starts to boot then it gets to the window screen for only a few seconds and the screen goes dark and the "B" & "C"...
B and C usually indicate a drive failure. if issue only occurs on COLD boot and successive boot attempts gain access to the OS, then the most likely issue is that the HDD is slow to come to operating speed, (Drive has to be at Approx 97% of rated rotation speed before is can successfully read) on drives where the spindle is slow to come to speed, a cold boot then successive warm reboot will often gain access to the HDD/OS
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
One problematic issue on diagnosing this is that you only have 1 opportunity to run diags (The cold boot) and get a reading on if the drive is failing to read (also because diags are generally slower to load, the drive may come up to speed before the diag actually runs)
If issue is problematic and getting worse, I'd replace the HDD
Oct 22, 2010 | Dell Precision Workstation 670 PC Desktop
No logical drive drives found dell presicion 670
If the problem would be the logical drives not found it means that your drives are defective. Though it is working but the board on the drives does not. Replace the drives and then start the installation of your operating system.
Sep 08, 2010 | Dell Precision Workstation 670 PC Desktop
Need internal drive for dell precision 670
You have two options with the WS670. You can use standard IDE (PATA) drives or you can use SCSI drives (up to Ultra320). If you are already using SCSI HDDs in the system, you would most likely be best served by sticking with SCSI for your hard disks and leaving IDE for your optical drives which I believe is the default configuration, but it can be modified when ordering the systems. If you are already using LVD drives, just go ahead and slap another one in of any size. If you want to use IDE, your maximum size will be dicated by the chipset used in the system (information not available on the Dell website).
Jun 09, 2009 | Dell Precision Workstation 670 PC Desktop
Dell Precision 670 throws "BIOS not installed!" message
i think this means that the harddrive needs to be refoarmated as the bios sees no logical drive in which the boot.ini file resides
Sep 01, 2008 | Dell Precision Workstation 670 PC Desktop
Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Jan 18, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 PC Desktop Logo
215 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
