Question about Nokia 6120
My mobiles backlight dont working, its work only when i taking pictures... what i must do?!!!
  • 4 Answers
Yup its not torch light if you want torch light start video and then you can use it as torch light...
Posted on Feb 18, 2010
How do you fix a Samsung 55" Television with no picture but good sound?
The symptoms you described would indicate the backlights are not working.
The 2 main reasons are the backlight inverter board has gone or the backlights have blown!
Since you have replaced the inverter board with a new working one then this would point towards the LED backlights.
Apr 02, 2016 | Samsung Televison & Video
My Samsung DVD TV 15G10 is 3 years old and has functioned perfectly until the other day when I turned it on to view and since have had only sound and no picture. Grateful for any thoughts on how to...
firstly i dont know how the video is hooked up to tv - so if what i recommend doesnt work i would suggest giving more details
if video is hooked up to tv through component video (red, green, blue wires) try checking the green wire- if green wire is bad you will get no video on your screen you can try using one of the other wires to test if you dont have a new component video wire to try
secondly if that doesnt work try hooking the source up to a different input on tv and see if that works
next i would try another source for your video to be hooked up to tv ( maybe a dvd player or something like that)
if all of those tries dont work you might either have had the bulb for the back light go bad ( backlight bulb is usually a flourescent light bulb and it makes the screen get bright so you can see it) or the power supply for either the backlight bulb or the video high voltage go bad in which case i would recommend bringing in for service or just buying a new replacement (they are fairly cheap to buy new now so it might be a better alternative to a repair)
sometimes you can tell if it is backlight problem by making room very dark and look carefully at screen to see if you can see a picture on it - if you see a faint picture on screen then it is definately your backlight that went out
if you need more help write back with as many details you can give me about what wires you have connected things to tv with and what sources you have connected to tv also
good luck!
Mar 25, 2011 | Televison & Video
I have a norcent 32'' tv and later when i turn it on there is no picture but i hear sound, the control dont work either. I have to unplug the tv and wait a little and then plug it back in and it will work...
The LCD inverter backlight board is dying.Replaced this board to solved picture problems.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.The board is a long board in shape.
Mar 03, 2010 | Televison & Video
VIZIO VW42L I have sound but no picture.
if there is entirely no backlight then yes, however if you just dont have a picture and just a blue screen then it is not the backlight it is the inverters, replace both is recommended.
Sep 19, 2009 | Vizio VW42LF 42 in. LCD HDTV
Camera turns on fine. I could view picture and all. Just that when I switch to camera mode a video screen is blacked out. Why is that?
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
Sep 04, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
My tv shows a picture for about 10 minutes then no more picture but sound remains. what could the problem be? thanks
One of two problems:
1) You have a problem with your power board/inverter. This is most likely the result of busted or bad capacitors on the power board. If you know what you are doing, you can try opening up the TV and taking out the power board and replacing any bad capacitors using a soldering iron. If not, take it to someone you trust.
OR
2) Your LCD backlight panel is going bad. The backlight is the light that shines through the LCD to show your picture. This can be fixed by 1 of 3 ways, you replace the whole LCD panel and backlight (expensive), you can get your hands on a broken LCD of the same size with a working backlight and swap out the backlights (takes time and knowhow), or you can actually repair the backlights themselves (much harder and somewhat dangerous).
The fact that it happens consistently or after 10min implies that it might be an issue of the backlights overheating until they shut off or power board overheating to the point where it can no longer provide enough power for the backlight. Try keeping a fan on at the side or back of your TV and see if it makes a difference. It may or may not make a difference, regardless of the issue.
Aug 15, 2009 | Hitachi Televison & Video
My lcd backlight doesn't work anymore..
noway As an experience mobile technician I diagnose that the problem of your phone is the LCD Connection maybe dislocated if not broken due to falling down the unit. You better consult technicians around you.
Jun 12, 2009 | Nokia 5200 Cellular Phone
I buyed me a sync cable for my phone to take the picture off of it and put them on my computer and it dont work it charging my phone but that it
for taking picture form your phone you need also a sync program from you mobile company like for example: for nokia PCsuite, HTC Active Sync
Aug 08, 2008 | Computers & Internet
Movie is playing, but will dont display on screen
Try increasing the contrast. If that doesn't work, then make sure your input is on the correct setting. Press the input button and wait for a picture to load (about 5 seconds each) while trying to play a DVD. Also, make sure that the backlight is enabled. If you take it out into the sunlight and you are able to see a faint image of the movie on the screen, then you need to turn your backlight on. Most likely an option in the main menu, but it may also be caused by a broken sensor that senses when the player is closed and turns the backlight off, but also turns it back on when the player is opened.
Feb 11, 2008 | Zenith DVP615 Portable DVD Player
Backlight on sidekick 3
Because your screen is broken and that can only be fixed if you have it replaced.
Jan 14, 2008 | T-Mobile Sidekick II
Nokia 6120 Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
