Question about Whirlpool Washing Machines
The clean water pump is flashing on my whirlpool awo/d4505 washing machine where is the pump and how do i clean it ?
    President:
  • 2,501 Answers
There should be a access panel on the front of the machine at floor level.
This will have a filter which you need to clean. This filter is on the input to the pump.
Posted on Feb 03, 2010
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool awo/d4505
Change the filter material.
Jan 20, 2009 | Home
Whirlpool washer
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
Jan 20, 2009 | Whirlpool Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
742 people viewed this question
Dan Webster
Dan Webster
Sal De
