Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
Brush is not moving...not sure if it's the belt...anyway to find out how the belt should be installed?
  • 701 Answers
Most likely it is the belt. Check to see if the belt is broken or the teeth have worn off. Here is the belt you need and the manual:
Dyson DC17 Belt and Manual
Posted on Feb 04, 2010
Dyson model DC07 the belt controlling the beater bar is not turning but does have tension
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dc07
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dec 09, 2016 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My powerhead drive belt to the N137A electrolux model has broken. I have a new belt for replacement but do not know how to install.
Turn the PN bottom up. With a Phillips screwdriver, remove the six screws in the base. Turn PN over and lift back of cover, then gently manipulate it until it comes off.
Slide the belt off motor shaft, if necessary. Remove the screws on each end of the brush and lift the end of the brush so you can remove the belt, if necessary. Place new belt on brush and place brush into slot. Replace screws and tighten. Pull belt back to motor shaft and slip on. Check belt for tautness. There should be a little play, but not much. Make sure belt is placed correctly and rotate brush a few turns.
I recommend cleaning the inside of the PN while you have it apart. Use the dust brush to vacuum as much as possible out.
Make sure the light cover is in the correct position. Carefully place front lip of PN cover into slot in front.of the PN. Carefully settle cover in place. Check around the PN to ensure cover and base are correctly placed. Turn PN over and replace screws, short one in front.
I do recommend letting a trained Aerus Electrolux tech do this, especially since the belt will have a one year warranty if he/she does it. Of course the belt should last longer than that, anyway.
Mar 03, 2011 | Electrolux Epic 6500 Vacuum
The brush on my vaccum stopped rotating, we replaced the belt thinking that could be the problem. It seems that the belt is working fine and the brush will not rotate even manually- what can I do to get it...
Remove the brush from the machine and clean as best you can. At each end of the brush there is a plastic clip that holds it into the vacuum. Add some WD40 between the clip and the brush and turn the clip around the brush until it moves freely. Do this for both ends. Reassemble making sure the belt is properly installed.
Oct 13, 2010 | Bissell 6595 Lift Off Bagless Upright...
Power spen brushes move very slow or stop
Not sure if you are speaking of a vacuum or steam cleaner or ?
If it is a vacuum, sounds like the beater brush is freezing up. Follow the directions to replace the drive belt. When you get the beater brush off the unit, clean it as best you can. Add a bit of WD40 between the ends of the beater brush and the hard rubber pieces that hold it in place. Before reassembling, turn the brush while holding the pieces one at a time to be sure the beater brush turns freely. When you reassemble, be sure the belt is properly installed.
If you find this solution to be helpful, I would appreciate an appropriate Thumbs Up rating from you.
Be well, Paul
Oct 06, 2010 | Vacuums
I have no suction from the bottom
If there are no obvious air leaks, check to see that the belt that turns the beater brush is not broken and that the beater brush has not frozen up. Remove the beater brush and clean it, spraying a bit of WD40 at each end by the hard rubber pieces that hold it in place. Turn the beater brush by hand to be sure it moves freely around the rubber pieces. When you reassemble, make sure the belt is properly installed.
Oct 02, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The belt keeps breaking. Like it's burning through.
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Sep 17, 2010 | Dirt Devil Breeze Canister M082550 Bagless...
Turn on motor just humms
If the motor is actually running and not picking anything up, I would believe it to be either a broken drive belt for the beater brush or the beater brush is frozen or both. Remove the beater brush and clean, paying special attention to the end pieces that hold it into the vacuum. If possible spray a little WD40 on them to be sure they turn freely on the brush. Also a good idea to replace the belt, but be sure it is installed correctly in order to have the brush move in the proper direction.
Sep 16, 2010 | Oreck XL2800 Bagged Upright Vacuum
8955 Upright Vacuum: How to change belt?...
Be sure to unplug your vacuum from the electrical outlet before proceeding!
-Turn your vacuum upside down so that the handle is resting on the floor and nozzle portion is resting on a work bench.
-Remove the 2 phillips screws from the metal bottom plate and set the bottom plate aside.
-Look at the right side of the brush roll. You will see a bent metal rod that attaches to the brush roll end cap. This is the clutch rod that allows your brush roll to spin or not depending on the position of the carpet/floor switch on the top of the nozzle. Pull this rod out of the brush roll clutch only. Leave the switch end of the rod where it is and just let the rod rest there.
-Pull the brush roll and old belt out and dispose of the old belt.
To install a new belt; put the new belt on the motor shaft first, next put the other end of the belt over the end of the brush roll and stretch belt and brush roll back in to place. Notice that on the brush roll end cap opposite of where the clutch rod goes, there is a metal piece with a slot cut into it. Be sure that this slot mates with the plastic stop in the nozzle so that the end cap cannot move.
Snap the clutch rod back in place and rotate the brush roll by hand to make sure the belt is not pinched.
Replace the bottom plate.
May 18, 2010 | Riccar 8955 Upright Vacuum
Got Dirt Devil Featherlite,keeps burning the belt out immediately and there is only one way to put the belt on...have put on 4 new belts.....what up?
Hi There,
When a belt breaks immediately after installing it, this can ONLY mean one of two things. The first is that the belt was put back on incorrectly, and it may be pinched underneath of the beater bar. This would cause it to break immediately, but I seriously doubt after 4 belts that you put the belt on wrong all 4 times.
The second, and more probable cause is that your roller brush has gone bad. This could be why the belt broke in the first place. In order to test to make sure the brush is bad, unscrew the bottom plate, and remove the brush like you were changing the belt.
Hold the brush at the very end on both sides, using only your finger tips. While holding just the bearing caps, try spinning the bar with your thumbs. Does the brush spin freely in your hands? It should spin completely around 4-5 times on each spin. If the brush will not spin, or if you feel any resistance to it spinning, this is the reason why your belt continues to break.
If the brush can not spin, the motor shaft will continue to try and spin the belt, but since the brush doesn't spin, and the belt doesn't move, the motor shaft will just burn right through the back end of the belt.
If your machine is actually the model that's listed on this Fixya repair page, the Dirt Devil Featherlite model M085845, then your machine uses the following roller brush:
Dirt Devil Plastic Brush Roll for Model 085845 Part # 2-881020-000
The next time that change the belt, install the brush back into the machine, but this time pull up on the belt towards the brush to make sure that the belt spins freely, and spins the brush as well. If the belt doesn't spin the brush, there's some issue, and the belt will break as soon as you turn the machine on.
I hope this helped you. If you find out that you don't need a new brush, feel free to use the comment section here on the repair page and let me know, I'd be happy to walk you through some more advanced diagnosing. If you found this helpful, please be so kind and rate my repair and / or leave feedback for me.
Thanks so much,
Chris Jones
GoVacuum.com
Apr 21, 2010 | Dirt Devil Featherlite Bagless Vacuum...
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
85 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
