Hi Elaine I want you to check 2 things the striker mounted on the body may be loose and moving inwards when you close your door and the door does not catch all the way leaving the door lock in the open position / or the plastic sleeve is missing on it ==if that's ok then go to the actual door lock itself and check it with a screw driver by pushing the lock jaws closed and pulling the door handle to see if it release's spray it with silicone spray/ PB blaster /WD-40 or any lubricant you have handy I really think the striker may have loosened and this is your problem but the actual door lock could have failed you say it works then it doesn't so that makes me feel that the striker has moved also check the door handles to make sure they are not stuck in the applied open position lubricant will help here also here's a couple of photo's for you
check for the sleeve shown here<<< and check that the nut is tight and that the striker is not placed to far inward that the door lock can not close on it if it is to far in it will grab sometimes and not all the time and the door will be open look for metal scraping marks where it is located if it moved you will see these and also the original marks on the door post where it was originally installed
open the handle and spray lubricant in to make sure the handle is not staying stuck in the open position
spray the handle through the opening when you pull the lever to make sure that it is not staying in the open position
check the lock jaws by pushing with the screw driver and pulling the door handle to observe the lock function and lubricate here<<<<<<<< I the lock is not functioning you have to get a new one I hope this helped you out Good Luck
