Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
I'm working on a Bosch Aquastar 125 and replaced the diaphram and water valve. ONE of the three faucets this unit serves only gets tepid H2O, even though it is drawing 1.5+GPM. Why would two faucets work and one not get hot? Thanks, Jay
    Problem Solver:
  • 3 Answers
Balancing spool on the faucet ?
Posted on Feb 04, 2010
The other day our Aquastar 125 pilot went out. No problem, I relit it. It has gone out several times since then. But when I relight it, it often turns the burner on as if the faucet is running. AF
Safety valve is overheated water.
Sounds like the flow control sensor or other sensors, or pc board are bad.
You need service technician to diagnose problem and replace part.
Or replace whole thing with tank-type heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Oct 10, 2014 | Bosch Water Heaters AquaStar 125 series...
How to light the pilot light in a bosch aquastar 125 fx ng tankless water heater
I have the same machine first they said replace the micro switch i did then rebuild the water valve did not enough gas presure had it checked revented the unit the unit is brandnew relubed the water valve idk
May 11, 2014 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
My pieps froze and now my tankless water tank leaks how do i get a new part
Bosch Aquastar 125B Water Heater Repair Parts Pre January 2003
Bosch Aquastar 125B Repair Parts Selection Grid
This web site has Aquastar 125B parts. It appears your unit was manufactured 7/7/02, so that is what I pulled up for you. At least this will be a start for you to locate the part. I hope these links work.
Bosch Aquastar 125B Water Heater Repair Parts Post February 2003
Mar 27, 2014 | Bosch AquaStar Indoor Natural Gas Tankless...
Eratic hot water flow
Bosch 1600H NG??? I suppose. If so you need a digital manometer.
Take a static (off) reading then leave it hooked up and start flow. Watch pressure draw down and you should see the heater draw Water Column down below 5" as the pocket of NG in the pipe just before the unit draws down to minimal to keep heater lite. In that case problem in gas line size/gas line run length, Meter pressure.
If you have and maintain in operation 5" WC then is probably the water valve needs rebuilt along with a new diaphgram and also the water filter should be replaced too. This occurs esp after 2-3 year as Bosch specs rebuild at 3 yrs on the Maint Schedule. Also clean all the faucet aerators for good flow above 1.25 GPM Min at all faucets.
Under a single faucet flow (laundry sink) of 2.25 GPM the flame bed of the Unit should be 1"+ high and uniformly Blue.
I assume at this time you either have a Maint problem or you could be overflowing the heater's Winter capacity. This unit @ 70F rise only makes about 2.2 GPM. It's strictly a single use faucet heater at 117,000 BTU.
When you do the Maint look to see if there is corrosion between the GV pushrod and the water valve pushrod. Notice there is a huge mis- match in the 2 rods sizes.These units occasionally (more the 125B) corrode there and the GV will seize on and boil the heater dry and open a seam so you really want to maintain it to Bosch Specs and Schedule.
Note: This is a gas appliance & requires skill and knowledge to service. While Bosch may say you can DIY, I'd readily advise a Bosch approved Service Tech or Plumber do any rebuild. The Digital Manometer alone is a $100-150.00 item and it's the ONLY way to get accurate gas pressure readings.
Mar 14, 2014 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch aq 125 no water preasure
Clean water filter yearly or monthly. Page 16 example manual.
http://waterheatertimer.org/pdf/Bosch-125BO-NG-LP-outdoor.pdf
Shut off the installer supplied cold water supply valve.
Disconnect water pipe going to the back of the water
valve. Remove filter from back of water valve. Clean the
filter and inspect for damage. Replace if the filter is at all
damaged. Inspect the top of the water valve for signs of
a water leak or corrosion. If present, rebuild the water
valve.
Bosch service bulletins:
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/38b-125-series-bulletins.html
Descale heat exchanger yearly.
http://waterheatertimer.org/pdf/Bosch_Descaling-heat-exchanger.pdf
Sep 29, 2012 | Bosch Water Heaters AquaStar 125 series...
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Bosch GWH 1600 Tankless hot water heater. Sometimes it would spark, I would turn water offf an on a few times at the valve, and it would click and start. I took about the Hydro Generator, I...
Having the same problem with mine. Looking for a replacement generator. Seems that if your water pressure or flow is not adaquate your will have this problem. Get worse over time. I took mine apart and it got better then started doing the same thing again. I turn on several faucets to overcome problem. Still it not good. The 1600H does not appear in the Bosch website parts list models. They do say that a third party does the fulfillment in the notes at bottom on other units...maybe call them
Dec 24, 2010 | Bosch 1600H-NG Natural Gas AquaStar...
Heater not getting started.batteries are o.k.
Sounds like the 125X unit. This unit has a brass water valve. Be sure to service the water valve every 1-2 years. It is the most common cause of the 125 series heater not working. There is also an inlet filter screen on the water valve that needs to be cleaned or replaced.
Mar 15, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch 125BNG burners not firing
the diaphram is the pushing force for the gas valve to open, if you have a split or worn diaphram it will ned to be replaced.
Feb 21, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch 125 Tankless Water Heater - Water not hot enough
sounds like your mixing valve or tempering valve not unit.Somewhere there is a unit that prevents scalding temperatures- I expect this is your issue find and adjust this first- there are directions on it when you find it.
Nov 30, 2008 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
256 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
