Question about Brother MFC-5840CN All-In-One InkJet Printer
My brother printer not working well
MFC-5840CN Brother printer, I changed the black ink and it still complaint about color (yellow, cyan, magenta) ink low. But I check the color ink are 1/3 - 1/2 left. It's won't print anyway,
What should I do? I tried used the warm water to color ink liquidable. but it's still not work to print.
  • 677 Answers
Are you using Genunine Cartridges!!!!
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 04, 2010
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
I changed all Print cartridges-Black, Yellow,Cyan,Blue
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Jan 29, 2010 | Brother MFC-5840CN All-In-One InkJet...
What is cyan ink
It must be referring to the cyan color cartridge.
"Cyan" refers to the blue-green color cartridge.
Most printers have either 2 cartridges (black and multicolor), or 4 cartridges( black, magenta, yellow, and cyan).
See here:
http://en.wikipedia.org/wiki/Cyan
Hope this helps.
Jan 13, 2010 | Brother MFC-5440CN All-In-One InkJet...
Model HL-4040CDN, told me to change magenta toner
Have the same problem, can't find the solution. Filed a complaint on the brother website feedback link, hopefully they will resolve if more people post problems with toner cartridge changes
Nov 10, 2009 | Brother HL-4040CN Laser Printer
Brother mfc-240c
The digital display on the printer will tell you which color is low and when it needs to be replaced, either black, magenta, cyan, or yellow.
Oct 02, 2009 | Brother MFC 210C All-In-One InkJet Printer
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
No black ink printing
Ah, solved already. Cleaning the black print head a few more times did it for me.
Mar 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
Brother 3240x
See this page. The models of Brother's cartridges for the MFC-3240C are as follows:
  • black: LC41BK
  • cyan: LC41C
  • magenta: LC41M
  • yellow: LC41Y
Jul 12, 2008 | Brother MFC-3240C All-In-One InkJet...
Mfc 420cn
Do use original brother ink to fix the problem: Do the cleaning twice (All colors and bk). You should see some blocks of the missing colors. If not printhead is damaged and cant be repaired (Dryed out or damaged valve or clogged with particles). If machine displays unable to clean, search googl for ERROR 46 (Reset and change of waist inktank)
Sep 03, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
302 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
