Question about Science & Laboratory
How do I fix a mechanical stage from ''drifting'' downwards? Won't stay in position.I move the stage up into position under the objectives but as soon as I let go of the knob the stage drifts right back down again
  • 45 Answers
You need to tighten the coarse adjustment so it generates enough friction to keep the stage in place. How to tighten it will vary from scope to scope, but most just have the screws on the knob (metal circle inside the knob with two holes in it). To adjust this type, you'll need a special key wrench.
Posted on Feb 22, 2010
Hyundai problems
It sounds like the latch assembly to me. Go to the dealer buy one and install it.
Aug 24, 2014 | Hyundai Accent Cars & Trucks
How do I fix a door locking issue?
Inside door mechanical issue broken
Aug 24, 2014 | Cars & Trucks
Model 917-372832 Eager-1 5.5 HP . Stopped running . Won't restart. I believe the timing may of moved. How to remove the fly wheel to check key position? The key may have stripped. Hit a rock which may...
Hi, you are correct, the key will be sheered. Remove the top shroud and flywheel nut, then while pulling upwards on the flywheel have someone strike downwards on the crankshaft with a hammer and brass drift. Do not use a steel drift as it will damage the crankshaft. Hope this helps, regards Phil.
Jul 18, 2011 | Craftsman Garden
WHEN I STARE AT AN OBJECT, IT SLIDES DOWNWARD I
Adjust the settings with the webcam, maybe it needs calibrating. Most webcam has face detection so it needs to be adjusted.
Mar 04, 2011 | Vision G1163801207 Webcam
I lose power and stall when i engage clutch to spin snowthrowing blades on my mtd 24" two stage snowblower. any way to fix?
You probably have a small rock or stick jammed in the smaller throwing auger. Carefully rotate the small auger backwards using a stick/board and tapping with a light hammer till the jamming object pops out. Be careful not to place your hands or fingers in even if it is not running. Worst case scenario the worm gear that rotates the larger auger is broken and jammed and needs replacement. If both augers move freely then you will have to remove the cover under the motor and inspect the belt drive mechanism.
Feb 21, 2011 | Mtd Products Yard Machines 158CC Tiller
The stage slides down on its own and the view gets out of focus.
Just inside the coarse focus knob you will see a "chrome" ring with holes it it. That ring needs to be tightened just a bit. It will make the coarse focus knob stiffer so tighten only enough to stop the downward drift of the stage. A funny looking tool should have come with the scope. It is used to adjust this "tension" ring.
Oct 22, 2010 | Swift M2251C Monocular Microscope
The focus knobs drift
Oct 13, 2010 | National Optical 138-MS Monocular...
Swift microscope no 634008 having problem staying in focus when switching magnification
First, a scope of this grade will not be completely in focus as you move from one magnification to the next. But it should be close enough that you do not loose your point of interest.
Be sure you are not pressing down on the stage specimen platform as you change magnifications. It is very sensitive to pressure. Also, be sure that the coarse focus tension is tight enough that the platform is not drifting down imperceptibly as switch magnifications. Look through the scope and watch if the image goes out of focus while you are watching it. If so, you have what is called "stage drift". This is corrected by tightening the tension on the coarse focus knob.
The tension adjustment is on the coase focus shaft. It looks like a chrome ring with about 3 holes in it. There should have been a strange looking tool that came with your scope. It is used to adjust the tension. If your specimen is "drifting" out of focus, simply tighten the tension ring a little bit at a time until the specimen no longer goes out of focus. Do not get it so tight that it is not easy to operate the coarse focus knob.
May 22, 2010 | Swift M2251C Monocular Microscope
The Belt of my craftsman 3x21 sander slowly moves off track.
There is a leveling (screw/knob) on the side of the belt sander. Turn it up and the belt will drift in one direction. Turn it downward and the belt will drift in the opposite direction. play with this leveling screw/knob until you reach a good balance and the belt will stop drifting.
Dec 04, 2009 | Craftsman 3 x 21" Variable Speed Belt...
2005 Ford Focus ZX4 AC switch in dash does not move the blend to control where the heat goes in car.The AC switch which attaches to the button and to the mechanism under the dash but the new switch stopped...
Sounds like there is a foreign object in the heater case. The only way to reapair it is to remove the object by possibly removing the heater case.
Nov 08, 2009 | 2005 Ford Focus
Science & Laboratory Logo
390 people viewed this question
Top Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
