Question about Jabra GN9330 Wireless Headset
CALLS DO NOT RING ON HEADSET - Jabra GN9330 Wireless Headset
I have the headphone icon on and it wont come off. I cant receive calls
having a headset logo in your phone it causes no ring tones and you cannot hear voice when someone is calling.... if you have a headset, try to plug it and then unplug it... see if the headset logo disappear or not... if not maybe there a problem in your headset terminal... see some expert to fix it....
Sep 09, 2011 | LG GT540 Cell Phone
My Plantronics Voyager Pro begin emitting a continual ringing when I pair to my Blackberry. I've tried deleting the headset and re-finding it and it still rings when connected. This issue first appeared...
It sounds like a defective headset. Call Plantronics directly at 1-800-544-4660 x 5538 to troubleshoot and if it's defective, they will assist in a replacement.
Good Luck from Headsets Direct!
May 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
LG HBM 730 Bluetooth
Dear Kathiwc
Why wud u want to use a headset to tap a call and that to to ur phone without u answering is it. You have not made urself clear towards the end of ur explanation.
Feb 07, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Help
Remote ring detection provides a low tone * triple beep in your wireless headset when you receive an incoming call. This feature requires a handset lifter accessory, such as the Plantronics HL1 or HL10. If you do have a handset lifter but do not hear the remote ring detection, please check the following:
  • Check the placement of the lifter. - Make sure the handset lifter positioned directly over the phone's speaker.
  • Try adjusting the phone's ringer volume. If the phone's ringer is too quiet, it may not trigger the ring detection built into the lifter. Try turning up the ringer volume of your phone.
  • Check the ring tone of the phone. - If your phone's ring tone provides short beeps or plays music, the lifter's microphone may not detect it. Try switching your ring tone to a traditional ring or long beep.
  • Does the phone have different rings? - For example internal calls vs external calls vs transferred calls. Does the phone ring the same for each type of these calls. If so try changing so all calls use the same tone.
  • Attach the optional "external ring detector" cable. This cable plugs into the lifter and provides a small, black microphone. It is included in the plastic bag of lifter accessories. Mount the microphone near your telephone's speaker. Click here for more details.
  • There are 2 versions of the Lifter accessory - HL10 and HL1. The HL1 is a larger older version of the liter with a more sensitive rind detector. Some phones will require the older version of the lifter.
  • Please view the On Line Compatibility Guide to see if the older version (HL1) will be required for your phone.
*Please note the volume of notification beep in the headset cannot be altered, it will always be a low tone triple beep .
Jan 15, 2008 | Plantronics CS50 Wireless Office Headset...
I cant hear anything out of my headset
Is the headset paired and connected to your phone? Is bluetooth turned on in your phone? Look for the bluetooth icon on top of your phone's screen. Let me know what model phone you have and I can help you troubleshoot.
Sep 03, 2007 | Motorola Mobility H700 Wireless Headset
H350 HEADSET
you may have the earpiece volume too low, because you will only recieve a bleep when there is an incoming call, not a ringing tone, or just set it to auto answer in the phone settings.
Aug 10, 2007 | Motorola Mobility H350 Wireless Headset
Why won't it ring?!
The same happened with my phone and it was a faulty soundcard. i took the fone back and they sent it off to find that it was a faulty soundcard and replaced it for me. Now the fone works fine.
Nov 15, 2006 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Jabra GN9330 Wireless Headset Logo
77 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
