Question about Dell 2400MP DLP Projector
Why does my projection look green if the colors are right on the computer?
  • 4,234 Answers
I'm going to guess that you are using an RGB cable to connect to the projector and the projector is expecting a composite signal. The composite signal would be what uses a yellow connector when you use hte red/whjite/yellow type of cable. All of the video is carried by the yellow. If the projector is expecting this and you send out component (RBG in this case), then the only video signal processed is the green. Since the green also contains the sync signal, the picture will be seen but green.
Check the menus on the projector. You should find a video selection area that will allow you to change to component input.
Please update this if you have any more questions.
Dan
Posted on Feb 03, 2010
Background color green
adjust the red/blu/green grayscale knobs they should be in the back and, clearly marked.
turn color off then adjust until grey looks right then: turn color knob back on.
Mar 17, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Projection tv
the blue gun is not working properly which explains the dominance of green and yellow colors. you need to look after dry-joints on the blue gun circuit board, sometimes oil leakage from the lens may also affect the board
Mar 26, 2009 | Philips Televison & Video
Scrolling Green color on screen
If the lines are like pin stripes going from left to right then you most likely have a defective green crt
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Color setting ......
you have t adjust it to the green to get it to set right, if it ont line up youll need to have it converged
Oct 27, 2008 | Akai PT5598HD 55" Rear Projection...
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Samsug rear projection tv, everything looks green
Dust accumulation in color wheel, light tunnel, chip area can cause green tint.
It is very delicate area, light tunnel and chip can be easily damaged. Remove light engine assembly and color wheel. Blow dust out. Re-assemble. If the gasket around the color wheel housing is not replaced in the right position, or the housing screws not tightened correctly dust will contaminate the color wheel/light tunnel area.
Call someone that has done it a few times. If near Calgary, call me.
easyab
Jul 14, 2008 | Samsung HCM4216W 42" Rear Projection...
Green color
Hi...this could be the colorwheel. Very common in this model and an easy fix too.
Mar 20, 2008 | RCA HD50LPW42 50" Rear Projection HDTV
Colors not right
If "colors are not right" means red,green or blue separation =
convergence mis-alignment. That repair requires replacement
of the convergence IC's, a PCB overhaul.Above average tech
ability required...............Do you want step-by- step how to.....?
Nov 17, 2007 | Mitsubishi VS-60111 60" Rear Projection...
Color problem
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 06, 2007 | Hitachi 51F59 51" HDTV Projection...
Problem with green color
One of your convergence IC's has burned out and needs to be replaced. If the green color is sagging from the top or bottom then the IC that handles the Green Vertical (GV) is bad, and if the green has moved inward on the left or right sides then the IC that handles the Green Horizontal (GH) is bad. Toshiba projection TV's typically use the STK392-110, and it is a good idea to go ahead and replace both IC's with the updated STK392-150's. If you do not have experience replacing convergence IC's then have a qualified tech handle it for you.
Jul 02, 2007 | Toshiba 40H80 40" Rear Projection...
Dell 2400MP DLP Projector Logo
324 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
