Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Showing black screen with a blue line
Any idea what problem is? Sound is fine, changing channel is fine, no picture just black screen and blue line. Thank You,
  • terlyn Feb 27, 2008
    Problem was yoke width circuit . Thank You slinteriors.
  • Panasonic Master
  • 8,617 Answers
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Posted on Feb 22, 2008
Is T-con Board in Legend TV MOdel LE3233B THe cause for no picture just vertical Lines Have good sound
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 23, 2015 | Televison & Video
Picture went black except for partial green and blue lines &2 thin red lines
Vertical scan section circuit fault. Check and replace damaged component/s at its vertical scan output section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 17, 2014 | RCA MM36100 36" TV
Sharp tv #27sc26d no picture have sound
There is a voltage loss in the main board. It will be best to contact any experienced service technician, as the work is a skilled one.
Jan 03, 2013 | Sharp 27SC26B 27" TV
Can you fix this cracked screen problem on Vizio VW42LFHDTV10A? and no sound?
We used to say have a short service on the patio and buy a new set---damaged panel display unit is more than set cost (if it is even available)
Let it go---when damaged it can instantly damage other boards/parts in the set.
Run a car with no oil and see what happens........
Mar 20, 2012 | Vizio VW42LF 42 in. LCD HDTV
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Apex gb5108
'I to am getting only wavy blue lines, no sound, doesn't even show channel indicators. TV was off for 4 days, came home turned it on and ten minutes later this screen appeared, it wont even show the menu screen, different channels or video inputs no sound either.
Jun 21, 2008 | Apex Digital GB5108 51" Rear Projection...
JVC TV
civilman, the first set has either no high voltage or is collapsed vertically, until someone checks for high voltage there is no concrete answer, the AV27730 is vertical collapse from your description, either the voltage to the vertical IC is missing or the vertical IC has failed, not a big deal cost-wise, hope this answers your questions, if not e-mail me back, good luck, BMW Rider
Dec 20, 2007 | JVC AV-27730 27" TV
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
Screen now showing blue line at bottom
Sounds like, you have a bad optical block. Part can cost $550 to $800 + labor
Mar 28, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
205 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
