Sony KDS50A2000 has a green picture. - Televison & Video
  • bweddings Feb 03, 2010
    Sony KDS50A2000 projection TV has a green picture set is about three years old
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The life of a projection TV is 10-12 years usually. And that of the bulb is 10000 hrs. However, the issue you are describing not tells you completely that it’s a Bad bulb. Start with checking for a bad optic block. It can also happen due to faulty focus control or due to sparks on the fly back transformer. Also make sure to check the connections of the lamp, make sure the connections are firm.
Also check whether all the cables from your cable box are fine and connected firmly. If yes then you'll need to pull off the front of the TV, behind the speaker grill there would be a panel. Remove the panel and check for a black box hanging over there. It has 6 controls on it, 3 are marked as focus and 3 as screen. You'll need to adjust the screen. If you turn these too high you can damage a tube. So, we are doing real small adjustments. Turn the color off on the TV and adjust the red, blue & green controls up till you get a fine picture. Also adjust the focus until you get a clear picture.
And, if it doesn't resolve your issue then it is an intermittent blue lamp, a bad driver transistor a bad connection on the blue CRT board.
Replacing a lamp is a costly affair, so before replacing you'll need to check all other things.
Note-- Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 03, 2010
  • 10,594 Answers
Does your Sony KDS-50A2000 show green picture on all inputs like cable, dvd etc?
How old is this TV and how long it started this problem?
What you have been tried so far to fix the issue?
These info will help me to diagnose problem and suggest solution.
Thanks.
  • Shahid Electronics
    Shahid Electronics Feb 03, 2010
    I was expecting answers of above 3 questions but you rejected the assistance?
4 Suggested Answers
roety
  • 585 Answers
SOURCE: Sony 50' LCD Projection KDS50A2000 has a green tint on the screen
Yes sounds like a bad light engine (Optic Block), expensive part, but sony has extended some warranties on these for two or three years
link hope this helps
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 26, 2009
  • 178 Answers
SOURCE: Sony KDS50A2000 power LED flashes green, then
4 blink is a fan error. This is caused by one of the three fans not spinning fast enough or has stopped completely. The fan that usually causes this error is the one over the bulb and toward the back of the set. The repair is not expensive, but to do the service correctly you must get all the dust out of the tv or the fan will clog up very fast again. Getting the dust out is kida tricky because you have to get the dust out without contaminating the light engine, if it gets contaminated you will get colored splotches on your picture. I recommend getting a pro to fix it, the repair should be fairly reasonable around $150 to do the repair. The fans are not that expensive.
Posted on Oct 08, 2009
SOURCE: KDS50A2000 Green light comes on briefly followed by red blinking.
I tried this solution last night. had a similar issue. opened up the back panel and cleaned the fan. just for the fun of it, i tried to turn the tv on and presto. it works fine now and i probably saved a bundle. thanks!!!
Posted on Apr 30, 2010
How do I fix?
Probably the replacement lamp is not correctly aligned. HOWEVER, if the band is not on the bottom, but is surrounded (above and below) with good picture, the cause is in the RED color circuitry usually the 'convergence' section. This type of failure is often due to a failing electrolytic capacitor. Repair is problematic and may be in the integrated circuitry.
Jul 23, 2014 | Sylvania Osram Replacement Lamp & Housing...
Sony kds50a2000 is stuck in pc mode (video #8 position) cannot bring up menue to make another selection.
the older sony sets had a reset move: set off, menu, 5, volup, power then 8 and enter, not sure if it works for this unit.
Nov 03, 2012 | Sony KDS-50A2000 50" HDTV
Where is the Lamp Door located?
The lamp door is on the back bottom left of the TV. You can get the manual on the link below.
http://www.docs.sony.com/release/KDS50A2000.pdf
Sep 27, 2011 | Sony KDS-60A2000 60" HDTV
Kds50a2000 sony tv i need the remote code
Sony has about a dozen codes. 10000 - 10005, 10046, 10071, 10084, 10130, 10172, 10249, 10324, 10351, 10353. Try each of these till you find the one to match your set.
Sep 23, 2011 | Televison & Video
KDS50A2000 Green light comes on briefly followed by red blinking light. 4 on then pause, etc. etc. Problem???
Jan 25, 2010 | Sony KDS-50A2000 50" HDTV
Sony KDS50A2000 power LED flashes green, then clicks off and flashes red four times over and over.
Oct 08, 2009 | Sony KDS-50A2000 50" HDTV
Eric
Aug 26, 2009 | Sony Televison & Video
Screen tint is green and I can't seem to adjust the color setting to fix the problem
This may be due to Optical block. Click the link below to review Certain 2006 Model Year SXRD Television Extended Warranty Information - Optical Block
http://esupport.sony.com/US/perl/news-item.pl?news_id=277&mdl=KDS50A2000
Aug 13, 2009 | Sony KDS-50A2000 50" HDTV
My sony kds50a2000 failed lastnight. Bulb only?
There could be something else that caused the lamp to fail but if it has 6 to 8 thousand hours on it that is the expected life and it is not uncommon for a lamp to fail this way.
Mar 10, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
