HP Pavillion 533w System restore disks
Hello my name is Richard here is the Problem
Situation: I have a HP Pavillion 533w. The owner of this CPU gave it to me so that i can install a new HD and reinstall all of his previous software and upgrade to a few others.
Problem was that I realized as i read through forums of HP's policy of the System recovery info being on the origianl HD is a partition, and that if you install a new HD I was going to have problems.
I must have read everything there is to know about this machine and the installation of System Recovery Disks. None od the solutions offered are helping and to make matters worse HP does not help people with this specific model anymore.
What I try to do is set up the cd as the main booting device,
then load the cd labeled number 1 of 8
then reboot
then the system shows the HP loading page
then its starts to read the cd but that's when the message shows
"Operating System not found"
I have tried everything,
The bios reads or sees the HD and labels correctly
I have tried the DVD in another CDU and works fine
I read and reread all manner of ways for this error and no luck.
So I hope someone can help
Thanks
Richard
  • richyj Feb 21, 2008
    Yeah but this is that one that is not being cooperative. I've tried three brand new formatted HDD and i get the same operating System not found message.
  • 43 Answers
You should be able to do a clean format with the hp disk on a new drive.Basically start from scratch.I have put new drives in HP computers without any trouble
Posted on Feb 20, 2008
My HP pavilion 533w will not completely power on.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
You might use the system restore to restore your system to an earlier time click start all programs
accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
If the system restore fails
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan power lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
Oct 18, 2012 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I recently was given an old HP pavilion dv1000 (PT111AV) (PT074AV-ABA) with out any of the documentation, recovery disks, etc. I installed a fresh copy of Windows XP Pro SP2, it works fine but I...
You can try to download CPU-Z & run it on your system just to figure out what chipset it has. That would be useful in finding out WHICH drivers to download. usually, once the chipset drivers are installed, the names of the onboard devices would start coming up correctly, even if Windows does not have native drivers for them. although I have never used CPU-Z on a system without chipset drivers installed yet, it's still worth a try.
Usually Windows driver updates through device manager should do the trick but it only works (effectively) when the chipset drivers are installed.
I've once been cornered in a similar situation for a Socket370 board (back BEFORE CPU-Z existed) so I know how this feels and I really hope this helps.
Aug 09, 2011 | Computers & Internet
Hp screen wont start up i just get the blue hp screen f10 = start up esc= boot menu f11=system recovery f9 = dignoses when i pree these buttonms nothing happens tried unplugging everything and still...
If pressing F11 ("system recovery") does nothing, then your disk-drive, which contains a "system recovery partition" is inaccessible,
i.e., your disk-drive has failed.
You'll need to buy a new disk-drive, install it, and use the original "System Restore" set of CD/DVD disks to reinstall Windows onto the new disk-drive.
Oct 11, 2010 | HP TouchSmart IQ770 PC Desktop
The picture scrambles several times during the day and the only way to stop it is shut the computer off at the tower and then restart and reboot. We borrowed a monitor to see if that was the problem but...
The picture scrambles because the video chip overheats and malfunctions. Open the case and do a full cleaning. If necessary add an extra fan - $10 at all IT shops.
Aug 31, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Hp pavilion 533w on startup goes to boot disk failure-insert system disk. I insert the floppy..it goes to A:/ & I type win as command and it says bad command or file name
Did it work well before? One thing I would check is the memory cards. Sometimes they get loose or the connection isn't good and the computer won't start.
The model I think you have is tough to open, there are directions on the internet if you need.
Another alternative, depending on your operating system, would be to use another computer to create a "start up disk" to use on yours.
There are also directions if you google it.
Could be so many things, just thought I would give you a couple quick things.
If this doesn't work, maybe I can be of more help.
Steve
Jan 28, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I have another computer, and cannot load my printer driver because I cannot locate my CD Rom. It is HP Deskjet D1520 It worked fine previously, but now does not communicate with my HP Pavillion computer....
Run system restore and restore windows to a previous state, if this does not work, then try to reload the driver, you can actually find the driver on the hp website
Oct 03, 2009 | Office Equipment & Supplies
I have a HP Pavillion 533w..a friend of mine was using the computer and decide to go to Local D drive and clicked on format...well i have no recovery disk and of course the system recovery will not work i...
You can take the drive out of the computer and connect it to another computer to see if there is any data on it. If there isn't, you MAY be able to have the drive unformatted professionally, but buying a new computer would be cheaper. If there is data on the drive you have other options, depending on what that data is. It could be as simple as making another partition bootable.
Apr 30, 2009 | HP Computers & Internet
HP Pavillion Programs freezing
Suggest restoring the system to factory settings. You will lose all of your data so back it up first.
Restore is either on disks or on recovery partition of hard drive. If you have recovery disks put first one in and reboot computer.
When the computer starts you should see an option to hit F10 for System Restore/Recovery. Hit F10, click advanced settings and choose Destructive Restore. Follow the prompts.
Will need to reload all programs after restore is done that did not come with computer such as Office.
Hope this helps.
Thanks!
Mar 19, 2008 | HP Pavilion DV4015cl Notebook
Pop ups and trojan horse
You could try installing www.spybot.com although this may not be possible without admin rights (you wont have permission to install the app)
The other thing you could do is boot in safemode (F8 at the start) and see can you install it now.
If its XP you could try do a system restore back to a point when your laptop was working. Then install spybot
Finally you could make a dos virus scan disk from your antivirus ofware and let it scan windows and your drive before the trojan is started.
It can be tricky to remove, but if you tell me the name of the trojan there maybe an application/utilitie to remove that specific virus.
Hope this helps!
x-b-m
Feb 20, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
836 people viewed this question
David Payne
David Payne
