Question about Konica Minolta Office Equipment & Supplies
I purchased a bizhub c550, I have no service contract, an error message has come up call service tech trouble code C-2A04, is there something I can do machine had been running fine.
    Problem Solver:
  • 5 Answers
C-2A04 this is an EEPROM access error fot the TC-K, try replacing the black toner cartridge (K)
Posted on Feb 14, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
How can I resolve error code C-2451
Release new transfer belt unit
• A new installation is not detected when a new transfer cleaner unit (image transfer belt unit) is installed. Remedy 1 Reinstall unit. 2 Check there is a short circuit in the fuse of the transfer belt unit. 3 Check the PRCB connector for proper connection and correct as necessary. 4 Change PRCB
Feb 02, 2015 | Konica Minolta Bizhub C550
Bizhub c550 code c d403
check all connections between the main boards start with having the firmware re-flashed via secure konicaminolta web site only tech have assess to, KonicaMinolta wants their firmware secured. secondly remove each connector on the board check for bent pin on the board connector, then re-seat each plug and there are a lot of plugs on each board!!!!!!!! worse case bad boards $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Apr 08, 2014 | Konica Minolta Bizhub C550
I have error coad c-3425
If the code comes back after conducting this procedure, do not reset again as the machine can catch on fire that will ruin a perfectly good day call a tech
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Feb 05, 2014 | Konica Minolta Bizhub C550
Bizhub c550 error code c3b04
IF THIS CODE COMES BACK GET A TECH YOU HAVE A PROBLEM WITH FUSER WHICH CAN CATCH ON FIRE RUINING A PERFECTLY GOOD DAY.
Feb 01, 2014 | Konica Minolta bizhub C450P Laser Printer
C-1116 message on Bizhub 500
In Konica minolta Buz C550 copier teh C-1116 error code refer to :
output OP center press transportation motor drive.Check the transmission driver mechanical components(gears,rollers).To reset press and hold on the Utility key and turn ON the copier,wait to displayed Trouble reset message,release the Utility key ,touch the message,turn OFF the copier ,wait 2 minutes and turn ON.
Mar 07, 2013 | Konica Minolta bizhub C250 All-In-One...
I have a bizhub C550 color copier a error trouble code C-2A04 just popped up what can I do to get it running its the weekend no service tech available!
Hi Kiddco,
Sorry, this probably a bit late for you. It's Sunday evening here in the UK.
C-2A04 is an internal error of the EEPROM.
The only thing you can really do is turn the main power swich (the big one under the flap) off and leave it for about 10 seconds. Then turn back on and cross your fingers.
I'd generally look over the machine too, just in case there's any paper stuck.
Good luck
Feb 06, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C252
1. Touch the following code on the trouble code display screen.
Stop → 0 → 7 → 1 → 3 → 9
2. [*] will be displayed on the trouble code screen.
3. Touch [*].
4. The screen will be shifted to the data restoration screen to perform data restoration.
NOTE
• When the restoration is performed in a short time, data restoration screen may not
be displayed.
5. Check the message which indicates that the data restoration was successfully conducted.
Turn Main power OFF, and wait for ten seconds or more to turn it back ON.
Try this please and tell your tech support service to change job....
DaSoP from Greece!
Aug 05, 2008 | Konica Minolta bizhub C250 All-In-One...
310 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
