Question about Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
Set to fax only mode, but will not pick up - Panasonic KX-FHD331 Plain Paper Thermal transfer Fax
    President:
  • 3,085 Answers
When you hear it ringing, press the START button.
Posted on Feb 03, 2010
2 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: detecting tel/fax
here is the manual
http://www.retrevo.com/s/brother+2800+fax+manual
Posted on Nov 27, 2007
Answ/fax do not work
Maybe it's not set to answer?
Press (fax icon) > (Menu icon) > Fax Setup > Receiving > Receive Mode
Make sure it's set to Fax mode.
Press (fax icon) > (Menu icon) > Fax Setup > Receiving > Ring To Answer
Pick the number of rings you want before the fax picks up.
Save and exit.
Apr 22, 2015 | Samsung C460FW Multifunction Printer...
Fax not picking up fax
hi do you have set your fax on fax reciving mode if not just set it it will be ok
thanks
May 11, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
We are not receiving faxes...telephone rings but doesnt pick up
the fax may be out of ink, out of paper , or set in the manual mode , I would think its set in the manual mode and has to be reset in the auto mode, go to settings , receive mode and set to auto.
Apr 08, 2010 | Brother MFC-8220 Fax
I want to shut off answering machine
Use the Reception Mode button to set appropriate answering mode - press it repeatedly until a small arrow on the display will point to the desired option:
"TAD" - is the one you are using now, when the answering machine picks up the calls.
"TEL" - is the setting when no automatic pickup occurs, you always have to pick up the call and either talk (if there's a person on the other side), or press START to receive a fax (when you hear the fax beeps on the other side).
"FAX" - is the setting when after four rings the fax will pick the call up automatically (no answering machine). If you pick up the call manually after 1-2-3 rings (before the automatic pickup) you can either talk or START fax reception.
It's good to check from time to time if the reception mode is as you want it, it's easy to change it by mistake.
Good luck and come back with a testimonial if helped :)
Jan 31, 2010 | Sharp UX 460 Plain Paper Thermal transfer...
I can't stop the fax from picking up all of my calls
there was a man/auto option under settings that was set to ON when it needed to be set to OFF. I changed it and now I can receive a fax manually when needed.
Sep 17, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Setting jx200 to manual and have ansewring machine connected.
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Jan 08, 2009 | Canon FAX-JX200
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Fax machine picking up all calls
You must set the FAX RECEIVE MODE to FAX ONLY. The factory default is FAX/TELEPHONE. You can find the proceedure to change FAX RECEIVE MODE in your owners manual. IIf you don't have an owners manual, try pressing the MENU button, then scroll to one of the following: INITIAL SET-UP, FAX SET-UP, OR FAX RECEIVE MODE. One of these should get you to the FAX ONLY receive mode setting.
Aug 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Logo
204 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
