JVC AV27F577 27" TV Logo
Posted on Feb 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound is a little off from the picture
I bought a new tv and the first one I got home had video problems - the picture was cut off a fuzzy, I took that back and got a new one - the picture looks great but sometimes the sound is a little off from the picture. It does it with regular tv, digital tv and occasionally even with a dvd. It seems like the picture is delayed just a little bit.
Is this something I should have them fix while it's under warranty or is it something not fixable....
thanks
adam
Anonymous
Level 2:
  • Expert 99 Answers
  • Posted on Feb 20, 2008
Anonymous
Expert
Level 2:
Answers
99
Questions
0
Helped
30883
Points
197
Yes, if is still under warranty, you have to tell them the problem and let them fix it first.
1helpful
My Sanyo DP42647 TV has sound but comes in very fuzzy not clear at all
have you checked it on video inputs on rear of set and also on tuner inputs to see if problem on all inputs?
5helpful
2answers
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
1helpful
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Can hear sound and see picture but it is all fuzzy
u need to reset the screen options back to regular spec if its not a 1080 p tv if its a regular tv you will need to use the 1080 p tv to fix it before you can use it on any tv
Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1helpful
2answers
Sanyo 32
resolder your tv maybe it has a cold solder
2helpful
2answers
No picture but has sound
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
No picture or sound
perhaps the xbox is causing the tvs to malfunction. i would get a new one. remember that xbox is giving everyone a 3 year extended warranty on the xbox 360
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
