My wirsbo thermostat up button works but the down control does nothing. I blew out the dust on back, tried holding the button down for a few seconds and tried pushing both buttons at once It is stuck on 75
  • 118 Answers
Replace thermostat these are non-servicable, Sorry!
Posted on Feb 04, 2010
Testimonial: "Thank you - replaced and all is ok. Sad it couldn't be repaired"
A few days ago my Playstation began freezing midgame while playing NBA 2k11. Now when I turn it on, all of the icons such as game, network, playstation network, friends, music, etc are on the home screen...
Hi mttwlsn16,
If you noticed that system recently freezes up, it migth be overheating or full of dust. There are several ways on how to check the issue, either you clean the system or place it in a cool area. Here are some ways to troubleshoot the problem.
1. Turn off the system completely then disconnect it from the power outlet. Press and hold down the power button for 15-20 seconds. Try to restart the system now. If still has the same problem proceed to step 2.
2 .Try to Unplug and replug all the cables.
3 .Take out the hard-drive, and put it back in after your console has been started up.
4. Make sure that you have at least 60% of the hard drive space free.
5. Clean your game discs with a micro-fiber cloth.
6. Clean the ps3 from dust. You can Use a micro-fiber cloth and use vacuum accessories to clean the dust from the grills and fans.
Alternative solution to remove the dust:
--> turn off the system by switching it off from the back. Please make sure that there's no inserted disc on the system.
--> Now hold the eject button and while holding it try to switch it back on. Fan will run for about 20-30 seconds and it will clean up the dust.
Hope it helps.
Thank you for using FixYa.
Feb 22, 2011 | Sony Playstation 3 (PS3) Console
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
Describe your cannot start ibook G3Problem it simply does not start, battery is ok and I have tried to take the battery away and back in its place, but nothing what can I do?
Make sure your iBook is plugged in to the wall. Hold down the power button for a few seconds. If that doesn't work, try holding down Command (the Apple key)-Option-P-R (hold all four keys down) and press the power button. Be sure to hold the power button for a few seconds whenever you turn it on.
If that doesn't work, try resetting the Power Management Unit (PMU). This is kind of a "last resort," according to Apple. Don't do this all the time.
  1. Reset the power manager by simultaneously pressing and then releasing Shift-Control-Option-Power on the keyboard. Do not press the fn (Function) key while using this combination of keystrokes.
  2. Wait 5 seconds.
  3. Press the Power button to restart the iBook computer.
If you have a very old iBook, you may have to unplug your iBook, remove the battery, and
  1. Press and release the reset button located above the Audio/Video port on the left side of the iBook (Dual USB) computer by inserting the end of a paper clip into the small hole and gently pressing the switch once.
  2. Wait 5 seconds.
  3. Reconnect the AC power adapter.
  4. Put the battery back in the computer.
  5. Press the Power button to restart the iBook computer.
(If it still doesn't start, do you hear the fans going?)
Good luck! Let us know if these steps solve your issue.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Apr 30, 2010 | Apple iBook G3 Mac Notebook
More problems
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Aug 01, 2009 | Samsung S860 Digital Camera
No power
fist make sure that the pwr selector is on the right setting. if that does not work look for the capacitors on the inside. if any have blown that could be your problem. if not im really hope that you did not touch anything on the inside while not grounded. with all the dust and movement you cold easly shock the circuits and fry the pc.
Try another pwr supply if nothing else works.
Jun 16, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Acer aspire blue screen appeared went off now laptop starts up for few seconds then turns off again, but always a black screen hear the fan a few seconds but nothing
Try this:
  • check to make sure the fan is actually spinning and that there is no debri (dust bunnies) causing it to overheat.
  • Make sure there is nothing preventing airflow, you may need to tilt the back up to allow more airflow
Is there any display at all? Do you see a BIOS splash screen? Do you hear a beep shortly after powering on?
--if you have a splash screen, go into BIOS setup by pressing a button (del,F1,F10...whatever) then set it factory defaults and save changes
--also try removing anything that's detachable (USB, cards, dvd-rom, RAM, Battery...) Hold down the power button for 20 secs then plug in only the A/C and see if you get a bios screen
Hope this helps
Jun 10, 2009 | Acer Aspire 5100 Notebook
Day and night heater and a/c unit heater would go
first try to pull the little white button out, it is a manual control button, and the out position is auto. If that does not work try taking off the cover, lightly hold the dial down while you adjust the settings. they are on the side of the dial, first setting is the off pos. set to 90, second is the on pos. set to 125-135. then put cover back on, while being careful not to push the button in.
Apr 03, 2009 | Honeywell L4064B2236 Fan/Limit Control...
No picture or sound
Hello. There are a few causes for this. I will list acouple solutions for you.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
2. Make sure the TV is on the correct seting. i.e. Video 1, Video 2, etc.
3. If option 1 does not work call Sony because the video out chip has blown or come unsoldered.
I hope this helps. Good luck to you.
Sep 13, 2008 | Sony Playstation 3 (PS3) Console
Xbox controller not working only has two lights on game pad
There should be a sync button right on the top of the back of the Xbox 360 controller. While the system is on. Power on the controller. Hold down the sync button on the controller, and then press and hold the sync button on the Xbox 360 console. Wait for a few seconds until the Xbox 360 controller lights stop blinking. Then test out the controller. Any comments of questions, post them by clicking on the add more details link inside of this question that you've asked.
Nov 16, 2007 | Microsoft Xbox 360 Controller
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
