Question about Brother MFC-9440CN Laser Printer
Display say "drum error" - Brother MFC-9440CN Laser Printer
  • shannon541 Feb 03, 2010
    this solution did not repair the issue.
    the diplay says remove cartridges and move green tabs. i do not see any green tabs.
    this did not repair the issue.
    display says "drum error" slide the green tab on each of the drum units. refer to users guide. I do not have a owners guide any longer and do not see the green tabs.
    help ?
    Thank you
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You’ll need to reset the toner menu to resolve the issue. Please follow these step-by-step instructions:-
1. Power on the machine and open the toner access main door. A ‘door open’ message will be flashed in the panel.
2. Now press the "Clear/Back" button to enter “Toner Reset Menu”.
3. Use the up ^ or Down > "Search" arrow buttons to scroll the reset options for each of the printer's toner cartridges - Code: B = black; C=cyan; M =magenta and Y=yellow
4. You can select the reset option for the cartridges to low yield=s or High Yield=h.
5. By using the number keypad select option #1 to reset each to the size you have installed.
6. Press the "Clear/Back" button again to get out of the menu and close the door.
You may also opt for Toner Save Mode to enhance the cartridge life. To select it open Printers -> go to default printer's icon -> Printing Preferences-> Advanced Settings-> select "Printer Functions" -> select Toner Save Mode from menu and turn it "on".
However this is not recommended for grayscale or photo printing. Now switch the printer on and print a test page and see the results.
If still the issue is not resolved then you’ll need to replace the drum unit.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 03, 2010
  • Rylee Smith
    Rylee Smith Feb 03, 2010
    It seems that you have to install the drum. If you have already installed it then you'll need to reset the drum unit by :
    1. Press Menu on the Control Panel.
    2. Press the Up or Down Arrow key to select Machine Info..
    3. Press OK.
    4. Press the Up or Down Arrow key to select Reset Menu.
    5. Press OK.
    6. Press the Up or Down Arrow key to select Drum.
    7. Press OK.
    8. Press 1 to reset the drum unit counter.
    Thanks
    Rylee
My printer says drum troubleshooting contact guide manual and maintence I did eveything but still not working
If the display shows drum error you can try cleaning it by following the steps below:
1. Open the front cover. 2. Pull the drum (black) and toner (gray) towards you, put a little force on it. 3. Remove the toner by holding down the tab on the side of the drum, then pull the toner out. 4. Use a dry lint-free cloth to clean the roller inside the drum unit. Make sure to remove any excess toner from it. 5. Put the toner back to the drum, make sure that it clicks, Reinstall the drum and toner back to the machine, 6. Close the cover.
If the display still shows drum error, go ahead and do the drum reset.
1. Open the front cover 2. Press the Options button on the control panel 3. The display should show "Replace Drum - 1. Yes 2. No 4. Press 1 to reset the drum count 5. Close front cover. The display should show the date & time
If still it shows drum error, The drum unit needs to be replace. After replacing the drum unit, do the drum reset again,
Hope this helps.
May 08, 2011 | Brother MFC 7420 All-In-One Laser Printer
Brother intellifax 2800. Replaced drum, display
Open the drum cover and hold down CLEAR for 10 seconds.
Jan 28, 2010 | Office Equipment & Supplies
Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Dec 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
We have a Xerox Workcentre Pro575; it has an error that says drum life warning; we replaced the drum with another drum that we know works, but the error stays on. What else can this error mean
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Nov 04, 2009 | Xerox Office Equipment & Supplies
Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
Aug 21, 2009 | Brother DCP-9040CN Laser Printer
HP CLJ 2840 - Engine error
It seems from the outside looking in that the drum may have frozen up the drive motor.
Remove the new drum and install the old drum and see the the error goes away.
Jul 06, 2009 | HP LaserJet 2840 Printer
Oki b4600 displays check image drum toner senror error
Try this:
Press Online
Press Menu repeatedly until MAINTE MENU displays. Press Select.
Press Item+ until DRUM CNT RESET displays.
Press Select.
Jul 01, 2009 | OKI B4600n Printer
Displayed error
sol:
1:you have to replace the drum unit.
or
2:open the drum unit & open waste toner cap &remove the waste toner & close the cap&insret the drum unit into m/c .problem solve.
Jan 13, 2009 | Canon imageRUNNER 400S Copier
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
Brother MFC-9440CN Laser Printer Logo
49 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
