Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
BOUGHT NEW CARTRIDGES (BLACK & COLOR) COST $70!! WILL NOT PRINT. SOUNDS LIKE PRINTING BUT BLANK PAGES COME OUT. . IS THERE A WAY TO CLEAN- UNCLOG PRINTHEADS MYSELF WITHOUT TAKING TO SERVICE MAN. CAN'T AFFORD THE REPAIR AFTER BUYING THE INK!! THANKS
  • 159 Answers
There are a few things you can do yourself to try and get the print heads flowing again, but they won't give you as good of results as a professional cleaning or new print head. I would say that the print head is most likely clogged if you let the machine sit for more than a few weeks without printing on it. If your last set of cartridges worked fine and then you immediately put in new cartridges and it didn't print, I would say the print heads may not be clogged but expired (no amount of cleaning will get them working again). To clean the print heads yourself first rub off any accumulated ink with a warm water soaked paper towel. As a check to see how your cleaning progress is going press the print head against a dry paper towel. You should see distinct entire lines for each color. You can then try resting the print head on a paper towel soaked in warm water to hydrate the print head. If no ink soaks into the towel at all after a few minutes the print head needs more cleaning than you can do yourself. Unless you know someone with a hand held garment steamer with a narrow nozzle on it you can steam the print head to loosen up the ink stuck in it.
Posted on Feb 05, 2010
Printer will not print text. will only print picutres and graphics and text on graphics. just replaced the black and white cartridge.
It sounds like you are either out of black ink or you have a clogged black printhead. Perform a nozzle check/test page, then do 3-4 printhead cleanings. Run another nozzle check/test page and compare it to the first one. If you see improvement, keep cleaning your printheads until the black printhead is unclogged. If you do not see any improvement, you may need to replace the black ink cartridge. (I am assuming that your printer uses a tri-color and black ink cartridge) Replacing the ink cartridge will give you a new printhead (attached to the ink cartridge).
Jul 05, 2010 | Computers & Internet
Do I need a color cartridge to print in black ink
the paper was black or blank? i think you mean blank, the ink will dry out over time replacing the cartridges will most likely solve the problem, or for the cost of the two cartridges u may want to consider a new cheap printer.
Apr 23, 2010 | Lexmark Z715 InkJet Printer
New HP F4400 going through ink too fast
It depends what type of things you are printing. If you are printing text, you should be able to print more pages. If you are printing photos, you are using more ink per page. If you use more of one color, you may also run out quicker. You didn't say if you were running out of ink in the black or the color or both cartridges. The black cartridge is rated at 200 pages and the color cartridge is rated at 150 pages. This is based on printing pages that may differ drastically from what you actually print. Here's a web link that explains this in more detail.
http://www.hp.com/pageyield/articles/us/en/IsoInkjetYield.html
Next time you buy a printer, spend a little more and find a printer that has a larger cartridge (check the number of ml (milliliters) in the cartridge). These printers cost a bit more but you will save on the cost of the ink. Cartridges all cost roughly the same regardless of how much ink they have. You can also look at websites that rate each printer cost per black and white and color pages.
Hope this helps. Good luck!
Mar 10, 2010 | HP F4480 All-In-One Printer
Mp960 color prints ok but black and white not printing
When was the last time you printed in color? New ink printers are built so with a "use it or lose it" theme. The print heads are now built into the machines and are not generally replaceable. Yours luckily is, but I don't know how easily. The link below is to the replacement which costs $130 + shipping. Sometimes it can be just as worth it to buy a new machine, in this case I would probably prefer to repair the damaged machine as the new printer cartridges cost more and have less ink.
Feb 16, 2010 | Canon PIXMA MP960 Printer
Was working fine. Ran out of ink. bought new black and color cartridges (ordered from Zerox) Cannot get printer to print in color or black. I have cleaned print heads etc.but to no avail. Thanls
There are some soft pads in the bottom where the ink cartridges sit.
Try this. Unplug the printer. lay some paper towells under where the print cartridges are inserted and drip some alcohol down into that area. That will soften and unclog the print head. Do that a ferw times to losten up the ink and flush it out. Then allow the printer to sit for a while then run several test pages. Most of the time that will resolve the problem you are having, Those liquid inks dry and get very tacky and will not allow ink to flow properly.
Feb 15, 2010 | Xerox WorkCentre M940 InkJet Printer
Hi. Printer isn't working, paper comes out blank.
Most likely the printhead is clogged. Another possibility is that the cleaning station does not work. 3 ways the printhead can clog,
1. Using Generic Ink
2. Not using the printer for a long time
3. Print a large print job after the ink indicator says the inks are running low.
You are better off replacing the unit than trying to get the printhead unclogged. Cost is usually around $40 and is only a 65% chance it willwork.
thanks
Dec 17, 2009 | Epson CX4600 Stylus Color All-In-One...
Can Someone Help?
If you installed new cartridges in teh color slot and it will not print from the computer in color, go into the printer setup menu, a button on the printer should take you here, and print an alignment page. If this fails to print correctly, select to perform a deep cleaning. This will use a lot of ink but will insure your nozzles are working correctly. If nothing prints or the color still isn't correct you will need to either manually clean the nozzles or have someone clean them. To be honest, depending on the cost of the printer it maybe more cost effective just to get a new printer than to have your manually cleaned. As inexpensive and printers are today I don't even replace cartridges anymore except for the black one. When the color runs out I get a new printer. The printer runs 35 to 39 dollars the color cartridge runs 35 to 37 dollars. But I don't do a lot of color printing. It is a choice the individual has to make.
Aug 28, 2009 | Dell A940 All-In-One InkJet Printer
Canon iP90 only prints blank pages
Did you try to wipe the cartridge.Maybe there's a clogs. inside.
May 28, 2009 | Canon PIXMA iP90 InkJet Printer
Canon ip4200
Hi You can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and fill Remove the empty and try to print,or you can buy canon refile "InkTec Canon BCI-5/BCI-6 color" and full it,it`s cheap instead to buy everytime a new cartidges. Good Luck
Aug 19, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
375 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
