Question about KitchenAid KDRP407H Dual Fuel (Electric and Gas) Kitchen Range
Broiler element comes on on Kitchen Aid KDRP407 on all settings
I bought my Kitchen Aid KDRP407 Dual fuel range several years ago. Yesterday, everything worked fine. Today, I made cupcakes, but the oven's broiling element came on instead of the normal element. No matter what setting I use, the broiling element comes on. I killed the power at the breaker box for 15 minutes thinking that might resent the electronics, but no luck. HELP, PLEASE
  • mattwyszynsk Feb 13, 2010
    Brad,
    I cut the power at the breaker box for about 4 hours; 15 minutes must not have been enough because after I powered up again, everything is working as normal. I'm not sure that I trust it yet, though. Everytime I turn the damn thing on to bake, I check to make sure that the broiler element isn't going.
    I've been baking bread with moisture (a pan of water on the bottom rack of the oven) and I'm not sure if that screwed it up or not. Did you do anything unusual before the problem started?
    Good luck,
    Matt
Have you resolved your oven problem ? If so, what was it ?
I have the same exact thing going on....
Brad
Posted on Feb 12, 2010
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Broiler not working and stains around gas burners
use a stain remover like hapic, or gbc and the stain will go off.
Aug 03, 2009 | Siemens HD2515U Stainless Steel Dual Fuel...
ERD30S- oven wont turn on
Hi! jpdufilho
Try tuning off the power to the unit for 20 minutes. If this does not fix the problem you may need a new control board/panel. If you have a lot of lightning in your area you should have several surge protectors in your house. All electronic devices need some type of surge suppression.
InMrFixIt
Nov 09, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dual fuel kithen aid F 02
Welded element relay on the control board.
Brian
Apr 18, 2008 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Broiler does not work
heres a link to your manuals, and as far as resistance for broiler? is it an electric broil element?? if so, you should have continuity through the element, if so its good
http://www.frigidaire.com/support/ResultsPage.asp?strModel=PLCS389DC&User=&Search=Search
Mar 21, 2008 | Frigidaire PLCS389DC Dual Fuel (Electric...
Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Nov 10, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Stove is suddenly haunted
F3 Oven too hot Replace oven temperature sensor it also sounds like you need a main control too..hope this helps
Aug 25, 2007 | Kenmore 75503 Stainless Steel Dual Fuel...
KitchenAid KDRP407H Dual Fuel (Electric and Gas) Kitchen Range Logo
298 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
