Question about Teac PD-H570 7-Disc CD Changer
Teac CR-H130 disc-tuner-amp with jammed cd's
I have a Teac CR-H130 disc-tuner-amp (3 cd player); by mistake, the lower cd holder has 2 cd's...jammed! Can you help suggest anything I can do w/o breaking it!!! Thank you so much.
robotek
  • 1512 Answers
SOURCE: Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Posted on Jul 07, 2008
petraman7
  • 1175 Answers
SOURCE: CD Player says no disc and clicks when CD is entered
That wouldnt damage the laser to my knowledge.
Turn it on ,open the drawer , unplug the AC get a can of "dust-off" or compressed CO2 and dust out the interior thru the drawer opening.
It MIGHT help
Posted on Mar 24, 2009
localwonder
  • 6784 Answers
This is a faulty loading motor. you will need to replace the entire optical lens assembly in this case. the motor is part of the assembly.
Posted on May 29, 2009
SOURCE: TEAC CD player jammed
I had the same problem in 2007: I removed the cover and manually encouraged the cd drawer to open. It has been working ever since.
Posted on Sep 14, 2009
taran_2005
  • 10515 Answers
SOURCE: I turned on my TEAC
Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminum cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should then be OK. If it has been forced, the aluminum cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
Hello, I have a TEAC D200, but I cannot record. I have used different CDs and when I press dubbing it says no disc. I found a blank disc that it recognized, but it does not record when pressing dubbin
1. check right (supported) sort of cd's you say rw is ok, check type!
2. such old model possibly has wear-out on laser or else
3. lots of dust inside; use @ least cleaning - cd... or equivalent;
good luck
Ganimidis
Dec 29, 2014 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
I have a 51 sony cd ..what else do I need?
Yes, Sandra, you need to plug this CD player into a tuner. Almost any tuner will work. Using a red & white audio cord (and any cords with similar plugs), connect the Line Out from the CD player to the Line In on the tuner. Depending on the tuner, you may have Line In inputs for CD player, AUX, and possibly others. Any of them should work.
If you don't have a manual for the player, you can download one from the Sony support web site at :
50 Disc CD Changer
Jun 12, 2014 | Sony CDP-CX53 51-Disc CD Changer
My TEAC Model CR-H130 combo 3 CD Changer and AM/FM Receiver/Player will not play CDs. When the Play Button is pressed, the CD will move from the rest postion to the play position within the unit; but...
The lazer is not reading the info off of the disc any more when they do that, It is verry costly to have it replace ,Minimun $180 end up depending on the model of it,
Dec 06, 2012 | Audio Players & Recorders
Cd tray stuck
The tray may be jammed, or the timing gear is out of sync, or a broken loaing belt.
Apr 26, 2012 | Teac AD-600 3-Disc CD Changer
Whats the difference between the teac rw-cd22 and rw-d250
I have a Teac RW-CD22 and it keeps telling me there is no TOC> I am unable to record a disc.
Dec 04, 2010 | Teac RW-D200 / RW-D250 Dual-Deck CD Player...
Own a crosley jukebox, cr-12-3. unit is not reading the cd's. any suggestions? i tried a cd cleaning disc. still nothing
Hi
if you can open the jukebox and look for the cd unit. under the place of the disc you should see the laser head its a small lense
try to clean with a qtips could be dust on the eye
it helped me when my cd player did not play
Hope it will help
Oct 21, 2010 | Crosley Jukebox CD Player with AM/FM Tuner
Why does Burn't Audio CD not play on some CD Players
because the codec's are different, if you have ever burned a avi file and it didnt play till you added say divx ir xivd to get it to play tech leaves out alot of the codec's so there system will work on most but not all cd's dvd's the only way around it is to find out which codec will work for that player to test what I have just told you take the cd to the store and try it on a different mechine and see if it works
Jan 14, 2010 | Teac AD-600 3-Disc CD Changer
TEAC MC D90
try different cd's my has the same problems. maybe due to early era of cd player. some cd's work ok. use as an amp with outboard cd player. good luck
Aug 18, 2008 | Teac DC-D2831 CD Shelf System
Getting ERR message on CD Player
My kids always cause this one ! Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminium cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should thne be ok. If it has been forced, the aluminium cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Jan 14, 2008 | Teac PD-H570 7-Disc CD Changer
Teac PD-H570 7-Disc CD Changer Logo
392 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
