Question about Refrigerators
GE Refrigerator, Model# TFX20JASM
12 year old side by side. Refrigerator portion is not maintain coldness. Don't have a thermometer to measure exact temp., but it definitely is loosing coldness. Freezer is fine.
What might be the solution?
    Problem Solver:
  • 19 Answers
YOU CAN BUY AN INEXPENSIVE THERMOMETER AT WALMART. YOU NEED TO KNOW IF THE FREEZER IS AT 0% . IF IT IS AT O% CHECK TO SEE IF THE FAN IN THE FREEZER WHICH IS CALLED THE EVAPORATOR FAN IS RUNNING. IF NOT THIS IS THE PROBLEM.
IF FREEZER IS NOT MAINTAINING O% AND FAN IS WORKING , CHECK THE LOWER PART OF THE BACK PANEL INSIDE THE FREEZER FOR FROST,IF IT HAS FROST ON THE BACK PANEL IT IS NOT DEFROSTING.IF SO YOU HAVE 3 POSSIBLE PROBLEMS.
CHECK DEFROST TIMER FIRST,MANUALY ADVANCE UNTIL IT CLICKS.IF THE HEATER IS WORKING FROST WILL DISAPEAR IN TEN MINUTES.IF IT DOES CLEAR FROST , FRIGE WILL COME BACK ON WITHIN 30 MINUTES.IF FROST DOES NOT CLEAR , TIMER MOTOR IS BAD,REPLACE.
IF ICE REMAINES YOU HAVE A HEATER OR LIMIT CONTROL PROBLEM.LIMIT CONTROL TURNS HEATER OFF WHEN COILS REACH 40%.LIMIT CONTROL IS A SMALL ROUND BI METAL SWITCH THAT IS CLAMPED TO COOLING COIL.THIS SWITCH HAS TWO WIRES GOING TO IT.
YOU CANNOT BYPASS THIS SWITCH . IT WILL CAUSE HEATER TO OVERHEAT AND MELT YOUR REFRIGERATOR PLASTIC AND RUIN FOOD.
AS YOU CAN SEE REFRIGERATORS ARE COMPLICATED.IF YOU ARE NOT MECHANICAL,ITS BEST TO USE A TECHNICIAN.
Posted on Feb 20, 2008
Gbscohbxercc referigerator freezing food
Could be a defective cold control.
Nov 28, 2013 | Refrigerators
Where is the defrost heating element
Freezer side at the bottom and maybe middle of evap coil. Need to remove screws to access
Jan 20, 2013 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
I have a Kenmore side by side model number 596.586.92890. The freezer maintains freezing temperature on the bottom, but not on the top. The refrigerator is not cold enough. The water dispenser won't...
You have a defrost issue.Occurs when door is accidentally left open.(even slightly for a period of time). You need to do a proper 12 hour defrost to resolve this problem.(Fan is jammed due to ice build up)
Nov 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FRidge/freezer not staying cold
i would focus on the defrost heater or heaters behind the back wall of the freezer.this is kind of common.
Aug 06, 2009 | Refrigerators
Refrigerator does not get cold - GE side by side
In my GE side-by-side refrigerator (model number GSS20IEMDWW), there is a motor-controlled flapper door between the freezer and fresh food side. Cold air from the freezer side cools the fresh food side when that flapper door is open.
It is located at the top of the fresh food side on the dividing wall between the fresh food side and the freezer. If this is blocked with something (large left-over container, soft drink bottles, etc), it _may_ be enough to prevent sufficient cooling of the fresh food side.
Of course, there may be a more serious problem with the flapper door mechanism or the control unit that signals the flapper door to open/close.
The vegetable and deli drawers may have a small opening (manually controlled with a wheel or a slider of some sort) that connects those drawers to the freezer side, thus explaining how those areas are still functioning as expected.
Jul 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Ref
Sounds like an internal mounting spring for the compressor. Only solution is replacing the compressor. However the compressor can run in this condition for years. Replacement compressors only have a one year warranty. A new refrigerator comes with a five year warranty.
Dec 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side-by-side Refrigerator too cold, runs all the time
If the problem is in the vegetable crisper drawer primarily, Google "WR49X10045". This is a simple fix kit for a design flaw.
Nov 28, 2007 | Refrigerators
Refrigerators Logo
330 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
