Question about York Yankees Bedding MLB Comforter
Low suction pressure - York Yankees Bedding MLB Comforter
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Where is the low pressure port in my 2008 ford edge
The larger hose is always the suction side (low pressure), not counting any hose insulation. The suction side quick connect is a larger diameter than the pressure side.
Jun 13, 2015 | 2008 Ford Edge
Where is the low pressure port to add R-134?
suction side of compressor is low pressure port to charge Ra134 . required quantity can be checked by returned temp. or designed suction pressure
May 29, 2015 | Cars & Trucks
Heat pump kicks out for "Low pressure switch open." Indicated by the leds on the defrost control board Happens 2 times and then shuts down for " Low pressure lockout"
Have you checked the pressures? if you have is it just the suction pressure low or are both the suction & the head pressure low? you could have multiple things cause that ex. low in freon, restriction, bad low pressure switch, bad board. If you don't know what your doing call a service tech. the LOW pressure lockout is a safety to prevent damage to your compressor.
Oct 15, 2013 | Ruud Defrost Control Board 47-102684-08...
Just want to make sure that the a/c low pressure line is located high is the a/c low pressure located in the back of engine compartment and high for easy access
Typically the the low pressure/suction line is a bigger pipe/tube, as far as location it depends on the car. The bigger AC line is almost 99 percent of the low pressure. Usually on the cap it will say most of the times to there is a different hydraulic fitting for the low and high side. Most cars I have seen have a little tag that will say suction or low pressure line, and or discharge high pressure.
If you are re charging the gas, always use the low pressure side of the system.
Aug 23, 2013 | 1988 Cadillac Seville
Low suction and low head pressure
What is your suction and discharge pressure? Sea Breeze
Jun 28, 2013 | Refrigerators
Above 78F no longer works gives heat head pressure is 300 and slightly above while low side varies bet 45 and 55 psi,noise in the return. i have about 85 feet of coil run 3/8 high side and 3/4 return from...
Your head pressure is a little high, depending on the ambient temp and your suction pressure is a little low. The suction pressure should be around 68 psig, the equivalent of a 40 degree coil. You can try adding a little refrigerant, check your compressor amp draw. If head pressure keeps going up and suction doesn't come up you may have a restricted metering device or filter dryer
Jul 17, 2011 | Goodman Heating & Cooling
How do you check to see if the high side is leaking back into the low side on a scroll compressor suction pressure is 90psi R-22 suction line is warm but not hot
90 psi is very high for R22....low for R410 refrigerant. If leaking by the head pressure and suction pressure will be close to to the same reading
May 10, 2010 | Heating & Cooling
I am working on a GE Weathertron Heat pump (Mod# BWB924A100C1; Ser# 264082948). The complaint is it is not heating as well as it once was(running a long time to heat up house). I checked the pressure, the...
It is very hard to charge a heat pump in the heating mode. The pressures are low. It also depends on the outside ambient temp. If you can turn to cooling if inside temp is above 70 degrees. Take a piece of plastic and block condensor till you get your head pressure to about 235. Not discharge temp but liquid pressure near service valve. You do not have a TXV inside I believe. Get your suction pressure up a little more It is not to low on gas. If you have temp meter attatch a lead to suction line. Temo\p should be about 10 to 14 degrees difference Between suction temp and Temp on your suction gauge. If you need a charging chart I can fax you one. Rus
Dec 04, 2009 | Heating & Cooling
Where is the AC low pressure port on a 2004 Dodge 2500?
I would think you found the low pressure port by now? But just in case most Dodge trucks I have seen have the low pressure port just above the compressor on the suction line. Of coarse leave it to Dodge to move it on some applications? Good Luck !
May 11, 2009 | 2004 Dodge Ram 2500
2000 ford taurus low end ac valve
please rate as fixed if this helps you.
The low pressure service gauge port valve is located on the evaporator to accumulator/drier suction line.
The evaporator to accumulator/drier suction line contains low pressure refrigerant gas and is equipped with a serviceable low pressure A/C charge valve port.
Apr 28, 2009 | 2000 Ford Taurus
York Yankees Bedding MLB Comforter Logo
79 people viewed this question
Top York Sport & Outdoor - Others Experts
paulcarew
Brandon Berry
Brandon Berry
Shehu Pro
Shehu Pro
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
