Question about Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator
MAYTAG MFI2067AES ICEMAKER NEEDS REPLACING
MAYTAG MFI2067AES FRENCH DOOR WITH ICEMAKER IN REFRIG SECTION---ICEMAKER NEEDS REPLACING---HOW DO I REMOVE THE OLD ONE? I'VE REMOVED THE BIN WITH THE AUGER; I'VE REMOVED THE 1/4 INCH HEX HEAD SCREW FROM THE UNDERSIDE AT THE BACK OF ASSEMBLY---WHAT DO I DO NOW, IT STILL DOESN'T WANT TO COME OUT!
DIYFRED
  • frednlindaw Feb 03, 2010
    THIS PARTICULAR MODEL HAS AN ICEMAKER THAT LOOKS A LITTLE DIFFERENT FROM THE ONE IN DIAGRAM---COULD BE WHIRLPOOL, AND I DON'T SEE
    MOUNTING BRACKETS.
    President:
  • 2,468 Answers
2 things possibly: check brackets and see if they need to be moved inward or outward as in they have bracket catches on the brackets so when you remove the screws the icemaker just doesn't fall off the wall of the unit,also check the center of the machine you may still have a screw holding the assy thats hidden
Posted on Feb 03, 2010
  • 4,070 Answers
I see what looks like a mounting bracket that would hang on a screw on this diagram. http://www.appliancepartspros.com/part_details.aspx?part_id=4292219&image=1
Here's the diagram of the entire area. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5169166&diagram_id=1322932#d1322932
Mfi2067aes digital display is dark
I think that that may be caused by a defective 67006294 Dispenser Control Board. .. Item location 13 in this PHOTO. I am here should you have questions, Thanks John T. Appliance 911
Jun 26, 2015 | Maytag MFI2067AES Stainless Steel Bottom...
Electricity off want to reset temperature. What should frig and freezer be set?
Temperatures are preset at the factory at 38 degrees or 3 C in the refrigerator compartment and 0 degrees F or -18 C in the freezer compartment. Here is a link=> MFI2067AES User Manual to the user manual for your model that explains how to set the temperature, I am here should you have questions Thanks Sea Breeze
May 29, 2013 | Maytag MFI2067AES Stainless Steel Bottom...
Hello, my freezer handle broke on my Maytag refrigerator model #MFI2067AES. I need to know how to get a replacement. Can you help?
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Aug 09, 2011 | Maytag MFI2067AES Stainless Steel Bottom...
How do I initiate defrost in a Maytag tri-door
Try this open the freezer door and flick the light switch 6 times, like flick, ----- flick,----- flick. If 6 does not work try 8, cant remember.
Aug 22, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Maytag Refrigerator is 69 degrees
You must check the evaporator fan motor in the freezer.
Is it running?
You may need to push the door switch with the freezer door open for fan to run with drawer open.
Next check the damper in the fresh food section.
Is it open?
Air circulating through?
If not, replace your damper control and thermistor.
Feb 21, 2009 | Maytag MFD2560HES Bottom Freezer French...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator ice getting all stuck together in one big piece looks like there is some water dripping in the ice box, I have changed the water...
sounds as if the icemaker is getting too much water and causing the unit to flood out. aside from replacing the icemaker you may be able to adj the amount of water going into the icemaker. there is a screw that holds the front cover of the icemaker inplace. remove the cover and you should see a screw  with a + and - sign on it. try turning the screw 1/4 turn then wait for the icemaker to cycle and see if it improves. keep making theses adjustments until your problem is solved thx peyton
Jan 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag MFI2067AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
311 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
