Question about Dell Dimension 8400 PC Desktop
I have a dell dimension 8400. The graphics card has VGA, S-video, and DVI outputs. I want to connect my plasma tv. I purchased a DVI to HDMI adapter and connected the two with an HDMI cable, but the computer doesn't recognize the TV, or anything additional.
    President:
  • 1,738 Answers
You may have left out a couple of steps.
Now, you need to configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab.
The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate.
If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently.
Now, again, reboot your PC to apply the changes.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Posted on Feb 03, 2010
  • J. Van
    J. Van Feb 03, 2010
    Note: After connecting the new cables, you may need to re-boot your computer before you can complete these instructions.
Can i connect my tv thru a dell optiplex745
Does your TV have a VGA port? If not it most likely has an HDMI port. Does your PC have an HDMI out on the video card? If not then you will need a VGA to HDMI adapter, OR a DVI-D to HDMI adapter, depending on if your GPU output is VGA or DVI-D. Then you will need an HDMI cable to go from the TV to the adapter.
Oct 17, 2013 | Dell OPTIPLEX 745 PC Desktop
+I have a dell 4600, it came with a geforce fx5200 graphic card, i need a vga and a hdmi coneection, my monitor is vga and i want to hook up a tv monitor with hdmi
Dear civetscat,
Hello and welcome to FixYa!
I have research these converters/adapters before that can convert from the DVI port on the video card to an HDMI source. They are very exspensive for the type that truely work, and the cheap ones provide terrible graphics. Your best bet, is to research both the adapter and a replacement video card for your PC that will have the HDMI and VGA outputs you seek.
I have provided links to both below, from a site call newegg.com
Adapter/Converter: http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=DVI+to+HDMI+converter
Replacement video card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161308
Happy hunting and have a great day!
Sep 01, 2011 | Nvidia GeForce FX 5200 Video Card Graphic
I have a Dell Dimension 2400 that I am running dual monitors on. I recently upgraded to Windows 7 professional from Windows XP and now I can't get both monitors to run at the same time. I have a Nvdia...
You should have 2 video ports on the 8400 GS card. One is the standard 15 pin VGA port and the other is the DVI port. You should be able to use these ports on the card to connect dual monitors. If you use the video port integrated on the motherboard you will bypass the 8400 GS card. Here's a link from Microsoft about running dual displays:
http://www.microsoft.com/athome/organization/twomonitors.aspx
The other issue is whether your monitors are DVI compatible.
Feb 10, 2011 | Dell Dimension 2400 PC Desktop
How can I connect Panasonic TH-37PX60U Flat panel plasma tv to my computer?
It will depend on your video output options on the computer. If you have HDMI output, just use an HDMI cable and an audio cable (this will need to be a 3.5 mm to RCA audio cable). If you have a DVI output, use a DVI to HDMI cable and the audio cable (or a DVI to HDMI adapter and either a DVI or HDMI cable depending on which side you want to put the adapter). If you only have VGA out from the computer, use a VGA to DVI adapter and the DVI to HDMI connection and the audio connection. (Theoretically this should work but each adapter will have some signal loss issues.)
Some graphics cards have a video output, S-video or Component video, which would also connect to your TV with the audio cable. (Read your cards manual for more information)
I hope this helps.
(For DVI to HDMI cables, you will need to check if you have a single link or dual link DVI output. The wrong cable may not work.)
Feb 20, 2010 | Panasonic TH-42PX60U Television
How can i connect dell dimension c521 to my tv my tv has a MDMI AND A DVI put cant fine thime on my pc
You can either buy a Graphics card with HDMI/DVI on or purchase a VGA to DVI adapter from most computer retailers.
~Plug the adapter into the TV and the cable from the PC to the Adapter.
Feb 16, 2010 | Dell Dimension C521 PC Desktop
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
Dell Dimension 4700 PC-I am trying to connect my pc to my HDTV. I was unsuccessful in using a VGA cable. I adjusted the output to 1280 x 780 x 60, but all I see is static. Help! Do I need a new video...
Yes, You will a new video card, if possible, one that is PCIe with DVI outputs andor HDMI outputs and as much onboard memory your budget will allow. The standard VGA port on your motherboard can not support the refresh rate of the HDTV thus the static.
Good Luck
C2Solutions
Sep 04, 2009 | Dell Dimension 4700 PC Desktop
Graphics card hdmi output to monitor digital input seems to not be working
i am having a problem with my sound and i need sound driver for dell dimension 2350
May 22, 2009 | Gigabyte Computers & Internet
How to conect a pc to a panasonic plasma th50px75u?
Panasonic didn't make it a simple matter to connect a computer to this TV since they didn't include a VGA input connector. You can still do it, but it will require some adapters or changes to your PC.
If you're using a laptop, you have two options. If the laptop offers an s-video output, you can use a suitable cable from there to one of the set's s-video inputs. If there's no s-video output, the other option is to purchase a VGA-to-component breakout cable, available at a number of online vendors (search with Google). This cable has the VGA connector to the computer on one end, and 3 RCA plugs at the other end. You would use this cable into one of the set's component video inputs.
With a desktop PC, you can still use one of those two options. In addition, there may be a DVI video output connector available as well. This is not common on computers with integrated video, but is frequently found on many newer expansion video cards. If your computer has this connector (or you install a new video card with one), you can use a DVI-to-HDMI adapter and connect an HDMI cable to one of the set's HDMI inputs. Many video cards with DVI outputs include one of these adapters already.
So while it's not going to be simple, it's certainly possible to connect your PC to this TV.
Feb 03, 2009 | Panasonic TH-50PX75U Plasma HDTV
Help
Step 1
Shutdown your computer and look at the rear of the case to determine the type of video connections that your machine has. Nearly all computers will have the standard 15-pin VGA output port. In addition, you may also find that your computer has an S-video port, an RCA composite video port, a set of three component RCA video outputs or perhaps even an HDMI output port.
Step 2Determine the types of video inputs that are available on your plasma TV. There should be a standard RCA composite input, a three-jack RCA component input and an S-video input. In addition, you may also find a 15-pin VGA input, a DVI input or an HDMI input. Step 3 Select which type of connection you will use. HDMI and DVI represent the highest-quality connections, followed by VGA, Component, S-video, and composite. If your computer has only a VGA output and you will not using it solely to drive the plasma TV, you may want to invest in a video card upgrade. Most new video cards will offer dual monitor connections and possibly a separate TV connection. The first monitor connection is intended for the main computer monitor, and the second monitor connection, or the TV output, can be used for either a second monitor or a TV. Depending on the card, the TV output may be DVI, HDMI, component, S-video or composite. Step 4Purchase a video cable long enough to reach from your PC’s video output to your plasma TV. If the distance is over ten feet, you may want to invest in high-quality cables to ensure that the plasma TV receives a clean signal for the best possible picture. Cables over thirty feet in length, depending on the connection type, may result in poor video performance. Step 5Set your computer’s screen resolution to something that your plasma TV can accept, using the “Display” settings in the “Control Panel” in Windows. Refer to the owner’s manual of your plasma TV for the supported resolution and refresh rate. If you are using the S-video, composite or component outputs on your computer, this step may not be necessary. Step 6Connect your PC to your plasma TV using the appropriate cable. Start the computer up and it should recognize the attached display. In the “Display” settings, you will need to configure how the plasma TV is used if it is attached a second display. Most video cards support “Clone” or “Mirror” mode, which displays the same content on both displays. In addition, there is the “Extended” mode, where the second display will operate independently, and windows can be dragged from one screen to the other. If your plasma TV is the only monitor for the computer, you will not to configure the multiple display modes. Step 7Connect a cable from the sound output of your PC to your plasma TV using the appropriate audio adapters. Then relax on the couch and enjoy your videos on the big screen.
Aug 09, 2008 | Computers & Internet
Dell Dimension 8400 PC Desktop Logo
380 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
