Question about Vacuums
I need the repair specs for a vt820 hibon blower ma thats the new style i need the torque specs the balancing techniques a repair manual would be great and i would be willing to pay
What size belt??
The Eureka Whirlwind 4489 uses style U belts, and you can find the Belt Package Assembly- Style U 2pk at the following link:
http://www.vacpartswarehouse.com/Eureka-Electrolux-Sanitaire-Belt-U-Style-2-pack-p/61120.htm
The broken belt usually stays trapped within the housing, so when you remove the necessary pieces in order to access the beater bar, you should find the remnants of the original belt, which you could also use to determine the size you need for a new belt. You might even get lucky and find that the belt itself is ok, but had gotten derailed somehow! Also good to remember is that there is often a second belt sealed within the packaging and instruction manual, so you may already have a spare belt on hand if you stashed the owner's manual somewhere.
Hope that helps! Please rate as helpful if so :) Thanks!
Jul 01, 2014 | Eureka Whirlwind 4489 Upright Vacuum
Head bolt torque for 1976 ford f-250 390 engine
Hello William, My specs. show 80-90#. I like to torque them in three steps, 70, 80, & 90# with oiled threads and oil under the heads of the bolts. Let the gasket do it's job... DON'T OVER TORQUE
Feb 26, 2014 | Holley 1975-1987 Ford F-250 Carburetor,...
I have just brought a janome sewing machine which does not have a manual,it says my style computer,only number i can find is 655000024,i would like to find a manual. thank you
Google knows mostly everything. :)
Failing that, you may want to visit a place where sewing machines are sold or repaired.
These folks are very helpful by nature.
Apr 01, 2011 | Vacuums
I can't find a user manual for my Eureka Model UMC-18 central vacuum system!
I have a manual that I can send you, drop me a line at my email and I will attach it back to you.
thanks
Mark
bartmkh@yahoo.ca
Nov 11, 2010 | Eureka 1810 Central System Vacuum
What Model replacement belt do I need for the Eureka model 2961 BVZ?
Greetings,
According to the Eureka Part diagram for your particular model vacuum, your vacuum uses Eureka Style U Belts. Eureka makes actually 2 different styles of U belts.
The first style is the standard U belt, Eureka part number 54312. This belt is probably the one that came standard on your model. You may purchase this belt from the link below;
http://eurekaservice.stores.yahoo.net/uprightbelt.html
The other type of Style U belt that will fit your model is the Eureka Extended Life Style U Belt, Part 61120B. The Extended U belt is more durable, and lasts longer then the Eureka Standard U belt. You may purchase the Extended U belt here;
http://eurekaservice.stores.yahoo.net/exlifubel.html
Now, if you are quite sure how to change your belt, you may visit the link below to see the owners manual for your Eureka 2961BVZ that will give you step by step instructions on how to change the belt;
http://eureka.com/service/manuals/80244.pdf
I really hope that this was helpful to you in finding and fixing the belt for your Eureka. If you did find this helpful, please be kind and rate my repair solution as helpful by clicking the thumbs up icon in the lower right hand corner below. I really do appreciate it, thank you.
Feel free to request a repair clarification if you have any questions about the procedure of installing the belt on your Eureka, I'll be happy to help.
Chris J.
Mar 12, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Brush roll turning very slow
You might need to clean out the roller brush. Here is the manual that has instructions:
Owner's Guide (1.5 MB download)
If you need a new belt you can get it here:
Eureka style D belt
Nov 21, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Is the style c the right bag. The vacum cleaner only runs about 5 seconds before it says the bag is full.
If you have a 6500, the C bag is the right one. Try turning the dial on top of the vac to the smallest dot and see if the machine will run properly.
If it is still doing the same thing, take it to your Aerus/Electrolux dealer for repair. The control valve assembly (full bag control) needs to be replaced and I don't recomend that you try the repair.
Joe
Nov 01, 2009 | Electrolux Epic 6500 Vacuum
Motor makes loud growling noise, no suction on model 270 i Miele canister style vacuum
Hi there SmartAlec from NelsonVacuums.com.au here. Unfortunately that normally means the motor has shot its bearings and/or its carbon brushes. I think it is time to purchase a new one. On the bright side there are some rreally great vacuums out there! If you want any help choosing a new machine send me a message. Happy Vacuuming :)
Sep 04, 2009 | Vacuums
Omc specs
You will need to repost this in the correct section, this one is for vacuum cleaner repairs.
Jul 13, 2008 | Vacuums
Vacuums Logo
217 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
