Question about Whirlpool Duet GHW9150P Front Load Washer
At 3 mins remaining f 11 error code appears - Whirlpool Duet GHW9150P Front Load Washer
  • 129 Answers
Clean out water pump
Posted on Feb 04, 2010
Kenmore Elite Washer Oasis Model: 11027042603 I have been getting a F1 code error with all wash cycles for the past month. It occurs as soon as I start the wash cycle and with 23 minutes remaining in the...
depending on its age take a look at the motors brushes. sounds like 23 mins would be spin cycle when the motor picks up speed. they may need replacing.
Dec 08, 2013 | Washing Machines
Clarion
Disconnect the car battery for 10 mins, reconnect the battery and then enter the radio code.
May 10, 2012 | Car Audio & Video
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
The washer stopped in the middle of a wash cycle. The error message was 11 F. I turned it off and turned it back on and washer stilled stopped and repeated the error message.
Hi
An "F-11" error code on a Whirlpool Duet could cause your washer to become inoperable and stop in the middle of a load. The cause of the problem could be a number of things and may require new parts.
F11 can mean anything from motor to motor control board to ccu board to wiring harness connecting ccu to mcu to motor.
Identification
The "F-11" code could appear with the dash or without the dash on the LCD screen. Be aware that there is also an "F-H" code that could look similar to the "F-11" code. Listen for 11 beeps to go along with the error code's first appearance.
Effects
The error means that there is no communication between the "Motor Control Unit" and the "Central Control Unit." This means that any operation selected like "Pre-wash" or "Large Load" cannot be sent to the motor for the washer to operate.
Prevention/Solution
Open up the washer panel to check the wire connections between the two units. If any plugs are loose or unplugged, reconnect them. Check to make sure none of the wires are stripped, rusty or broken off. After you reconnect the wires, rerun the washer to see if the error appears again.
Warning
If you do not know or understand the inside components of your Whirlpool washer, leave the job to a professional. Contact the store where you purchased the washer or Whirlpool customer service directly.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
# 11 appears when it trys to start...... not heating
Code # 11 indicates an Ignition Failure. According to the Owners Manual you should do the following: Check that gas is turned ON. Check that the vent termination is not blocked. Refer to the Restart Function explanation.
RESTART FUNCTION:
If the appliance fails to ignite, the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, 11, will appear during that hour and disappears after a successful ignition. If ignition fails again, then the fault code will remain and another attempt to ignite will occur in 1 hour. The fault code is not stored in the fault code history.
If the flame is extinguished during forced combustion then the appliance will attempt ignition after 1 hour. The "Ignition Failure" fault code, # 11 will appear during that hour and disappears after a successful ignition. Forced combustion takes place for about 15 seconds after ignition. After this time, the temperature control logic controls the combustion.
If the flame is extinguished (burner combustion failure) while the temperature control logic is operating the appliance, then the appliance will immediately attempt ignition. No fault code will appear.
In this problem repeats itself, contact you local Rinnai Authorized dealer/serviceman.
Hope this helps you to troubleshoot and solve the problem.
Mar 31, 2011 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Bosch excel 7 with F63 error code Cleaned the
my dishwasher will not dispose of the water and remains stuck on a cycle
Nov 27, 2010 | Bosch Washing Machines
Error codes E70 and E71 appeared and won't clear
what do E310 mean on a panasonic copier 7722
Jul 07, 2010 | Copystar CS-1510 Copier
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-12 EPROM error
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Kenmore he4t washer shows f-11 error
F-11 // WILL THEN APPEAR FDL CODE DOOR LOCK LOCK FAILURE, F-11 COMMUNICATION ERROR REPLACE MAIN CONTROL,, JUST REPL 3 TODAY ....
Nov 28, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
RE: Application Closed/reason:user/code:11
Phone type :W960
Problem: can not receive SMS when in Power On mode. Have to Power Off then I am able to receive my sms. But at the same time there is a message wathcher main thread error 11 creating dump file.
Have sent my phone to Erissson repair centre, they have totally format my phone and install the latest software version . No result. the problem still remain as before. They are not able to fix the . problem.
Would appreciate your help. Thanks Gani
Jul 08, 2008 | Sony Ericsson P1i
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
