Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
Sampson G track can work with adobe audition 3.0?
Can you download Adobe free from enternet. does it help see music videos on the net or any videos for that matter.
Adobe's a company. They make products for print and web design. You can buy their stock at an exchange, and you can download their software via the internet; but many of their products (including educational products all about Adobe Audition) are not licensed free of cost. Some are though, so check out Adobe.com. Adobe Audition is used in editing and compositing audio, as if it were software for making an audition reel; so music videos might (and do) credit Adobe Audition with having helped out making professional-grade work. Audition can come bundled with Adobe's CS5 suite.
Aug 28, 2011 | Adobe Audition 3 for PC (22011292)
I am using Adobe audition 1.5 for recording my songs.. now.. i am facing big problem while using that software.. there is multitrack option available in that software. we have put karaoke track in one...
Welcome to FixYa!
I assume that you know your way around adobe audition 1.5 because I'm currently using adobe audition 3 on windows 7. The menus are different, but I'm going to give a few points that might help.
Windows Sound/Volume:
Make sure that the sound card you are using is selected, specially if you are using an additional external USB sound card (which is much better). Disable other sound cards, if any.
Adobe Audition:
One of the pull down menus located on the upper part, it has an option that says "Device Properties" or anything like that. This is where you set the input signal will be coming from and likewise the output signal.
The input signal should be the input of the sound card you selected in windows. Same goes for the output signal.
On multi-track view, check the track to be recorded. Make sure that the input is from the input of the sound card and not from anything else. The button for the setting is somewhere near the Solo/Mute/Record buttons.
If this will be set correctly, you will be able to play the song on the 1st track and record ONLY your voice on the 2nd track.
Keep me posted.
Thanks for using FixYa.
Jas247
Apr 09, 2011 | Adobe Audition 1.5
Free serial key for Audition 3.0 anywhere?
Glad to help YOU!
Sorry to offer you this information... but THERE IS NO FREE SERIAL for Adobe Audition 3...!
Once you have purchased it you will get your UNIQUE serial that will fit that software.
But it's in your power to do a search on the Internet like "Adobe Audition 3 serial" and see what you will find out.... You'll never know!...
GOOD LUCK!
Mar 12, 2011 | Adobe Audition 3 for PC (22011292)
Hi, I can't seem to access the multitrack view on Adobe Audition. Every time I want to open a session file, it says to restart Adobe Audition. I have tried restarting my computer several times but it...
Did you check the logs? Rightclick stuff in the organizer window to send them to the multitrack, then name the tracks in multitrack if you can get it to open...or maybe your DDR2's falling out from all the bass?
Oct 26, 2010 | Adobe Audition 3 for PC (22011292)
Fast download of adobe audition for free
1- Partner with artists and producers at studios using Audition.
2- Get some fame and share props with Adobe Audition developers for a year or two.
3- Fast free download and license from Adobe!
Aug 13, 2010 | Adobe Audition 3 for PC (22011292)
Wats the serial number for adobe audition 3
1137-1897-4419-7897-9754-9086 this worked for me- hope it works for you too
May 26, 2010 | Adobe Audition 3 for PC (22011292)
No sound in waveform editing in Adobe Audition 1.5
try uninstalling and then reinstalling back Adobe Audition 1.5 or try out Adobe Audition 3
Feb 10, 2010 | Adobe Audition 1.5
In order to continue recording must restart adobe
Uninstall and reinstall Adobe, might be a corrupt file
Nov 03, 2017 | Adobe Audition 1.5
Can't record in multitrack
Adobe Audition 1.5
It seems your adobe audition 1.5 is missing file / files or adobe's registry has gone corrupt. If you ever run registry cleaners or registry fix some of them corrupt the registry of this adobe audition 1.5 try Reinstalling the Program and it should work. This Program is very Reliable and shoud have no problems with it. I use it all the time to download from internet and then edit to my requirement. I hope this helps. If you still have problems try to down load trial software from www.adobe.com Adobe audition 2.0 is free for download to try.
Good Luck
Jan 17, 2008 | Adobe Audition 1.5
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
288 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
