Question about Panasonic Toughbook 19 Laptop Convertible Tablet
Where do I find that wifi radio switch on my new
Where do I find the wifi radio switch on my new Panasonic Toughbook TF19 ???
  • 3 Answers
Http://pc-dl.panasonic.co.jp/dl/download/file/16957/s/28ef6385388fe6ee/19mk3_30mk3_52mk2-si4hspa-cpe02197za-xpvista7-M.pdf
Page 4
Russian admins and Google Rules!
Posted on Feb 28, 2011
Turn off automatic wifi panasonic cf-53
5 ways to turn off wifi,
thumb switch on front marked wi/fi
pull antenna cable from the card
or remove the wifi card
or disable in device manager in control panel system device manager.
or remove the driver /software for the card ,disable the find new driver
Jul 10, 2014 | Panasonic Toughbook Cf-53 Business Rugged...
Cf30 no wireless device detected
On the Panasonic Toughbook Model CF30, there is
a Wireless Switch located on the front side of the
unit when the cover is open and the unit is facing you.
The switch is on the right side of the handle near the corner
of the unit. Please make sure that switch is turned on.
Then check the device manager under Windows to
see if the device shows up, even with a yellow question
mark or yellow exclamation point. If it shows up in yellow,
then you are simply missing the drivers.
If it does not show up at all, then your CF30 might be
like several of my units that I purchased recently.
My CF30's had both a built-in GPS and a built-in
Cellular Modem Interface but as a consequence no WiFi.
I simply added a small USB WiFi no larger than a
wireless Mouse Transceiver and the USB cover could
close over the mini USB WiFi. $30 cost, problem solved!
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
Apr 21, 2014 | Panasonic Toughbook CF-30 Notebook
Cf-29 does not work anymore with my linksys. Ipad works with the linksys though.
On ALL older Panasonic Toughbooks the original
WIFI drivers were the original drivers which shipped
with the operating system.
These drivers usually have a date of 2003 or 2004.
There are NEWER WIFI drivers that work with the
latest routers (G or N). The new drivers have dates
of 2006 or 2007 for Windows XP and 2008 or 2009
or even later for Windows 7.
The CF29 MK1 used a WIFI "B" Adapter which is limited.
The MK2 used a WIFI "G" Adapter which will be easier
to update.
Panasonic CF29 usually used Intel Brand WIFI adapters
so drivers could usually be found at the link:
https://downloadcenter.intel.com/product/3821/Intel-PRO-Wireless-2200BG-Network-Connection
Good Luck!
Regards,
Panasonic Canada Toughbook Authorized Dealer since 1989
Feb 13, 2014 | Panasonic Toughbook CF-29 Notebook
Turn wireless lan
On page 75 and page 76 of the Reference Manual
for the Panasonic Toughbook CF51 is described
the procedure to turn "on" the wireless lan:
1 Double-click on the taskbar.
2 Select your wireless LAN adapter and select [General].
3 Select [On] for [Switch radio].
4 Select [Networks] and select [Add].
5 Enter the profile name and network name (SSID), and then make
other necessary changes, then select [Next].
6 Make necessary changes and select [Finish].
Please note that there is no Physical Wireless Switch
on the Panasonic Toughbook CF51.
You can find the manual here and double-check yourself:
https://panasonic.ca/PCS/OperatingInstructions/CF51MK1_X_E_Reference_Manual_A.pdf
Good Luck!
Regards,
Jan 22, 2014 | Panasonic Toughbook CF-51 Notebook
Turn on wifi
If you have 'Flight Mode' on the computer, make sure it's switched OFF.
Oct 28, 2013 | Panasonic Toughbook 19 Notebook -...
Can not enable wireless on toughbook cf-52 "radio is off"
Most Panasonic Toughbooks have a Physical On-Off
Wireless Switch Built-In. I belive the one on the CF-52
is located on the front right-hand side hidden behind
the handle. It is a small switch and you must slide it
to the right side (On) as opposed to the left side (Off).
Most modern Toughbooks also have a Wireless Switch
Utility which may be required. If so, you can find the driver at:
http://pc-dl.panasonic.co.jp/dl/search?q=&button=&dc%5B%5D=002001&p1=&p2=&oc=&lang=
That is it. Good Luck.
Regards,
Oct 07, 2012 | Panasonic Toughbook CF52 Notebook
I can't find the radio switch on my toughbook to activate wifi. I tried the yellow icon on the bottom right, but the wireless and bluetooth options are grey (cannot be selected) Thanks, Dave
http://pc-dl.panasonic.co.jp/dl/download/file/16957/s/28ef6385388fe6ee/19mk3_30mk3_52mk2-si4hspa-cpe02197za-xpvista7-M.pdf
Page 4
Feb 07, 2011 | Panasonic Toughbook 19 Laptop Convertible...
Wiil not scan for wifi
Make Sure the WiFi Switch Is Set To On, And The Light There Is On Indicating WiFi Connected..
Check Your Device Manager to See If Driver And Hardware Is Present...
Update The Wifi Drivers From The Toughbook Website
Dec 03, 2009 | Panasonic Toughbook W7 Notebook
Hi, I have a panasonic toughbook cf 19. How do i switch the radio button on so to activate the wireless connection IT SAYS ITS SWITCHED OFF.
You certainly have a n application managing the wifi signal,start that app.
and you should have control on it.
or go to services by rightclicking my computer and leftclicking manage
Services is nearly the last , then in the sevices list, locate wireless zero config, and if not activated & started, do it.
Wifi should then awake by itself
Nov 21, 2008 | Panasonic Computers & Internet
Panasonic Toughbook 19 Laptop Convertible Tablet Logo
870 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
