Question about M-Audio Studiophile BX8a Speaker
Hello, One of the drivers is producing a very loud hum when switched on. Also when I turn on the power the cone appears to be sucked inwards then the buzzing begins... Can you please, help? many thanks, Mike
  • 66mustangmik Feb 03, 2010
    Hey wow, Thanks so much!! I am so glad it was so simple to fix too!!
    Cheers,
    Mike
  • 542 Answers
This is due to you have connected the speaker wires are not proper, Try to reverse the speaker wire connection will resolve your problem. Also check the grounding is proper or not?
Revert back for more assistance.
Posted on Feb 03, 2010
How can I keep the buildings in pictures from appearing to tilt inward (Nikon D5200)
this most likely is a result of your lens your using , wide angle lens usually produce this effect (its a trade off for the wide focal plane) , try switching to a telephoto , or a not as wide ratio lens this will help
Oct 29, 2015 | Nikon D5200 Digital SLR Camera with...
My h2o mop won't steam. How do i fix it?
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
Apr 21, 2012 | H2o TR220002 Steam Cleaner
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
I get a loud intermitant buzz from one of my JBL eon 15-G2 speaker, no music signal just buzz. What is the problem do you think...? EQ circuit problem, speaker cones seem to be intact.
If you turn the unit on with no input and get a loud buzz, and when you put signal to it and you cannot hear the music but the buzz (Probably more like a hum). Then most likely the amp is blown.
Dec 13, 2010 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I have no audio device can not turn speakers on
Good day heigei, hi if you turn on the speakers but no ON lights came on, the problem is your Speakers' power supply stage, either a fuse opens (most likely) or something got burnt from the plug to the transformer, then to the rectifier diodes (got shorted then fuse opens) or to the regulator section. check also the power switch for poor contacts, of course you may need to open the speakers, If by any chance you hear something like hum.... check for open signal wire, check the IC amplifier also, a bad IC amplifier produce no sound or produce a loud humming/cracking sound. If you have no idea of what im talking about, have it checked by a technician. thats it.
Jan 20, 2010 | Altec Lansing VS2121 Computer Speakers
My Jensen spx 17 sub makes a loud thump on turn on.Is this normal or an easily solved problem? Will it damage the cone?
all the spx17 will do that, no it should not damage the driver.
We usually suggest to customers that it is best to leave the Sub in the Auto switch position as this will allow it to automatically switch on and off without the loud pop.
Nov 16, 2009 | Jensen Audio Players & Recorders
Reel to reel tape recorder hum
Try replacing the Electrolytic Capacitor(s) on the power supply. They will be big value anywhere between 2,000UF and 6800UF. But capacitors of this type are notorious for causing hum, any on the deck could do it!
Apr 05, 2009 | Audio Players & Recorders
ALESIS M1 ACTIVE MK2 CONE VIBRATION!
Hello!
my speaker Alessis M1 Active 620, with a roar is very strong in the speaker, the potentiometer does not attenuate, change the volume. Ja switched capacitor C8, based on my research of other users, but got no result. When you press the power button, the LED lights in blue, and even change the color to red, producing a noise (snoring) very strong.
help!
Please help me!
Mar 17, 2008 | Alesis M1-Active-MK2 Powered Studio...
Open Questions:
See all M-Audio Studiophile BX8a Speaker Questions
M-Audio Studiophile BX8a Speaker Logo
100 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Carlos L. Burgos
Carlos L. Burgos
Matthew Spark
Matthew Spark
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
