Question about AmcorAire UCHW-H24AF2 Split System Air Conditioner
PROBLEM I have had this unit for two weeks now. The unit is constantely pumping cold air. Just yesterday the unit starting pumping slower with air filled with humidity and very cloudy. The unit is not pumping as strong and makes some noise and there is constand smokey air coming out. I am very confused and have contacted many and no one has a solution. Is the unit just broke... Is there anything I can do????
  • noll44 Feb 21, 2008
    It has a heat and cooling option... yes it is a mini split
Hi well have a check on the compressor or refrigerant. check the blower motor also. hemish
Posted on Feb 22, 2008
  • 21 Answers
Is this a heat pump, mini split?
Posted on Feb 21, 2008
My Vulcan bonair evaporative cooler when turned on is making noise like its working but no air is coming through the vents. The pads disintegrated a few weeks ago and came through the vents. Has worked...
I would think you have to get new pads for it, they hold the water so the van can blow the moisture through them and then into the air. You should be adding a drop or 2 of bleach/javex to the water every week or so to prevent the grown of bacteria in the unit. it will cut down on colds etc. hope this helps.
Oct 20, 2017 | Heating & Cooling
A/c blower turns slow and makes puffing sound. bryant 80% avac system.little cold air from vents
Hello, replace the capacitor as when there are storms sometimes they can cause a voltage spike and damage the capacitor. The capcitor will be a round or oval metal looking can next to the motor. When the blower motor runs slow the coil can start to freeze due to lack of airflow and this is why little air is coming out of the vents. If the capacitor does solve the problem then the motor will have to be replaced.
Jul 01, 2012 | Bryant Heating & Cooling
I have a Lennex heat pump unit which was installed in 2008. Our area (Savannah, GA) has experienced some abnormal cold temps lately. Yesterday, I noticed the outside of the unit had frost on the unit. ...
Heat pumps are the same as an A/C unit only it works in reverse. Instead of blowing cold air inside and hot air outside it blows hot air inside and cold air outside. The heat being blown inside is extracted form the cold air outside. Its called Latent heat Latin for hidden. Believe it or not even though its 20 degrees outside there is still heat in the air. Example if you want to drop the temperature of a freezer from 20 to 10 degrees you have to remove heat .I know your getting unusal weather and that is the problem. Heat pumps can only work no lower then around 20 degrees outside.Heat pumps are never used above the freeze line. With your unusal temperatures thats basically where you are now. Ride it out. When your temps rise a little your be fine. Im in Chicago.
Jan 15, 2011 | Heating & Cooling
Cleaned coils/cage, a/c blows better but no longer cold
It would not be a slow leak, but you don't know, if your brother punchtured the coil. If the unit is less than 5 years old, it should be still under warrenty. If it is the coil, depending on the make . say lennox heat pump. the coil is $1,700.00, Coils are all different prices. It might be cheaper to replace whole unit. SORRY
http://www.heattransfertechnology.com/
Here are coil prices
Jul 04, 2010 | Whirlwind FH-778 Air Conditioner
I bought it three weeks ago and yesterday it stopped blowing cold air.. any thoughts? or just return it?
mcdevito75 here, Use your warantee return the unit. Also follow the units manual on operation.
Jun 22, 2010 | Haier hwr10xc6 Air Conditioner
My landcruiser runs fine at idle and whilst been revved stationaty, but under load it seems to starve for fuel this only started yesterday ... i'm looking for possible causes .. thanks
many things will feel the same when driving. if the lack of power is smooth without a shacking-missfire.remove the air cleaner element and see how it performs this way ,you could have a blockage in there ,ihave found mouse nests blocking this air pasage. you could have low fuel supply, plugged fuel pressure, low fuel pressure,bad fuel pump, you could have a plugged catalytic converter,this usually shows up as slower and slower speed when accelerateing at full throttle but will gain soom acelleration when backing of the gas.if its missing ,lock at the spark plugs, wires or fuel injectors.
Feb 28, 2010 | 1986 Toyota Land Cruiser
Air condition want cut off automatic
Hello, It sounds like your unit is going into defrost mode. Heat pumps struggle below 35 degrees F. Make sure the coils are clean so the unit will work at peak performance. They do make a heat strip to put in these units to help with cold temperatures. If you need more help just ask. Good luck.
Jan 23, 2009 | Whirlpool ACE244XS Air Conditioner
2003 Tahoe AC
The problem might be that you got out of freon gas.
Jun 12, 2008 | 2003 Chevrolet Tahoe
24000 btu split ac unit... celiera brand... BIG PROBLEM
is this air inside or out that is cold and cloudy?
Feb 19, 2008 | Fujitsu 24R1 Air Conditioner
AmcorAire  UCHW-H24AF2 Split System Air Conditioner Logo
137 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
