Question about Lexmark C540N PROD SPECS TBD Printer
Lexmark 540n 976:0 service network software
Lexmark 540n error message 976:0 service network software
Had the same probelm. Resolved it by disabling AutoIP feature in Network Settings. Also set hard IP without DHCP.
Posted on Feb 28, 2010
It was really difficult to find the place where it was the part that conteins the waste toner, but when I find it, was really easy. Thank you very much. Cristina
Posted on May 15, 2011
Had the same problem with a Lexmark X548. Problem was caused by having Brother BRAdmin Professional software installed on a computer on the same network as the Lexmark. This software periodically queries the network using SNMP and there is apparently a compatibility issue with the network code in the X548 that makes it lock up when queried by this software. Uninstalling the Brother software (or disabling SNMP on the printer) prevents the problem from happening.
Posted on Jan 23, 2013
How do i fix error 976.0 on lexmark ms410dn
A 976.xx error can be caused by IPv6 (i.e., internet protocol version 6) compatibility issues. It is possible to resolve this issue by disabling IPv6 in the Network Menu.
Jul 07, 2014 | Lexmark MS410DN Laser Printer - Monochrome...
I have an x642e all in one and the following message has appeared on the screen - 900.00 service R.I.P Software what shall i do? what doe3s it mean?
what is the exact error message?
am not able to understand the exact message.
please tell us clear.
and when is this error message shown?
Aug 14, 2008 | Lexmark Office Equipment & Supplies
How do i download firmware for a 900 firmware error - lexmark 540n
Before you download firmware, the 900 error usually indicates a software or communications problem. Please try to do the following.
Disconnect every cable, except for the power cord and turn off the printer for 30 seconds or more to clear its memory
  • Clear all jobs in print queue then turn on the printer and see if the error returns
  • If the error does not return, try to print a test page from the Test Menu
  • If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
  • If the
Jan 17, 2011 | Lexmark Optra T620 Laser Printer
Upon boot up, it doesn't complete, screen goes black, then message firmware error appears.
  • Do an NVRAM reset. Press and hold 6, 7, 8 upon boot up.
  • Boot up printer without network cable, fax line and options, see if error comes up.
  • Get the exact error message.
If problem continues, printer will probably require service. Contact Lexmark technical support(under warranty) or local authorized service provider for professional assistance.
Sep 22, 2010 | Lexmark X658DE All-In-One Laser Printer
How to fix message error 900.00 service RIP software on Lexmark c 530 dn
Does the error pop up when the printer is booting up, receiving information via network, connected via usb, or connected via parallel cable? It could be two problem. If it would post during printing, then it could be cause by a software or network problem. Test the printer in a standalone mode without any usb or network connection, if the error would post upon power up and without any network connection or usb connection then its a hardware problem. If it's a hardware problem, it would require a service call.
May 10, 2010 | Lexmark C530dn Laser Printer
MUTIPLE LEXMARK PRINTERS RUNNING ALL GETTING 976:0 SRV NET ERROR CODES
this network error being created in multiple units would be caused by a couple of things one is that you had a stormy day , and electrical storm or a power surge that has corrupted the nvram chips on the network cards they will need to be replaced. it is always a good idea to install surge protectors on your electronics
Feb 10, 2010 | Lexmark Optra T616 Laser Printer
Lexmark Optra 1275sc - 900 Service - Software Error
I have the same problem, but the error only occurs when I try to print a .pdf file (Adobe Reader) using the "Lexmark Optra SC 1275 PS" driver. For some reason the PS driver didn't like .pdf files! My solution was to always print .pdf files using the alternative " Lexmark Optra SC 1275 (MS)" driver, which Lexmark also offers on its website.
Apr 01, 2009 | Lexmark Optra SC 1275 Laser Printer
Error message on lexmark printer
900 Service RIP errors are usually a firmware failure. Upgrade to the latest firmware from Lexmark. This link is for the C52X network model:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Aug 07, 2008 | Lexmark C522n Laser Printer
Printer Lexmark T630
The error message is normally caused by either plugging accessories into the rip controller board or the engine board. In some models the board may be conbined. Or invalid or illegal commands sent from the printer. Try upgrading the firmware first. If that does not work you you may have a bad board. Hope this helps Click on the link below and select your operating system http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:359:0:0
Sep 10, 2007 | Epson Stylus Photo 1280 InkJet Printer
Lexmark C540N PROD SPECS TBD Printer Logo
3,894 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
