Question about GoVideo Go Video DVD/VCR Combo
I WAS COPYING A VHS TO A DVD..WHEN FINISHED A MESSAGE APPEARED SAYING BIT WAS COPYING FILE INFO..THIS MESSAGE ALWAYS APPEARS AT THE END OF COPYING..THIS TIME IT DIDN'T GO OFF. AFTER ABOUT 1/2 HOUR, I UNPLUGGED THE MACHINE, AS IT WOULD NOT RESPOND TO ANYTHING ELSE..NOW IT DOESN'T RECOGNIZE ANY DVD,RECORDED OR BLANK..I JUST GET AN "INCORRECT DISC" MESSAGE.
  • 44 Answers
One of two things have happened.
1) Either it's system board has has gone bad or
2) The dvd laser block has gone bad.
May cost more to service it than to purchase a new one?
Call around to a trusted service shop to get an estimate of repair.
Posted on Feb 03, 2010
Testimonial: "THANKS FOR YOUR HELP...I'LL PROBABLY START SHOPPING FOR A NEW ONE."
Copying of this material not allowed
try dvd -rw disks.also you may try going to menu see if there is a factory reset. if so rest. and see if this is the problem. also this message will come up if what you are trying to copy is copy-protected.
Jun 27, 2013 | Panasonic DMR-E75V Dual Deck Video...
VHS to DVD-R
You say "home made" - not sure what you mean by that. If it was a copy of something that was originally retail, it's possible the Macrovision encoding copied over with it - in which case your DVD recorder is working as it's supposed to to prevent illegal copying of disks. I'm a bit wary of getting into this in any depth, as it treads the lines of legality. If I found a way for you to bypass this copy protection, it would allow you to pirate movies freely. I'm not going to discuss my own feelings on that, but I will say that I'm not going to support such actions on a public forum. That being said, if for some reason your totally legitimate home made tape managed to get something that's being interpreted as Macrovision coding on it, you may want to do a google search for digital video stabilizer. That will point you in the right direction.
Aug 12, 2007 | Toshiba DR4 DVD Recorder
I hadnt used my machine in a while. I went to transfer from a VHS to DVD Loaded both - no problem After finishing the transfer the I couldnt get the DVD to eject Help please
Did you follow directions on how to transfer VHS to DVD ? When the dvd is finished copying it MUST!! finalize the copy. If you attempt to eject DVD while in FINALIZING it gets stuck. Try and unplug the power for about 1/2 hour. plug in and eject. p.s. read the manual....the machine is complicated!!
Aug 11, 2011 | Panasonic DMR-EZ48 DVD Recorder
I was copying vhs tapes to dvd successfully and then it started saying disc unknown.cant figure it out
this issue calls for a little info from my brain
have you tried to reset the recorder if so is there firmware updates for the burner
have you changed the brand of dvd disks lately if so sometimes a different disk has issues for some odd reason i have run into this problem before
Jan 03, 2011 | GoVideo VR3845 DVD Recorder/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
When copying a vhs tape to dvd, and there is only a short amount of video on the vhs tape, how do I just burn that and not the whole 2 hour tape? When I stop the copying it does not finalize and do not...
You must be able to watch what is being reocorded.
After the part you want to record is finished stop it.
Also the recording can be set for a set amount of time.
Jan 07, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
VHS record to DVD
Insert the VHS and rewind or fast forward to the point you want to begin copying from.
Insert the disc you plan to use and format it if necessary. It will usually prompt you if it is necessary to do so.
Put the television on the channel or input needed to view the recorder on-screen.
Select the DVD drive and set the record mode you prefer - XP, SP, LP or EP.
There are two things you can do:
1. Press and hold the dubbing/copying button on the recorder itself in the direction of the DVD for 3 seconds. If you are using a DVD-R/RW or +R you will receive a message stating to press Play to record without finalizing or press Record to record and finalize. If you are using +RW or -RAM, these cannot be finalized - therefore this message will not display.
2. You can access the Functions menu and go to Copy, then select the copy direction VHS to DCD and select Start Copying.
Apr 01, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
VHS to DVD - D-VR4XSU
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
DVD copying
There are double layer DVD's that they make which usually have about 2x the memory. check to see if your DVD recorder supports these types of DVD's. You could also just divide your media on to two sides of a double sided DVD (each side has the mirror look and you can record onto both sides)(still the same disc) or you could record on to multiple DVD's (may be inconvenient but is still an option). Also, you could reduce the recording quality just a bit so that it is not noticable when you watch it but it still uses less space on the disk. I would tell you how to do these things but I have no experience with the individual model that you have.
Mar 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Copying vhs to dvd
The write-protect tab on the cartridge is set to "PROTECT" or the disc is protected witht the "DVD Management" settings.
Some video tapes on the market(including rental videos) are copy-protected to prevent illegal reproductions. Copy-protected video tapes cannot be properly recorded.
You cannot use the copying function when the FUNCTIONS window, the Scheduled Recording List screen, etc. are displayed.
I hope this information can be of some help to you all. Ms Tanya 2/12/08 3:54AM CST.
Jan 30, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
69 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
